Man of Honour
- 16 Jul 2009
- Edinburgh
Folks quick question but is there a generally regarded "best" 6800 XT model? are there any that should be avoided?
This is the best, if your case can support the 240 AIO.Folks quick question but is there a generally regarded "best" 6800 XT model? are there any that should be avoided?
Hello Everyone!
Quick random question today, may seem like a bit of a strange one - I just recently upgraded from an old Zotac 1070 (served me well for 5 years) to a new ASUS 6800XT LC OC card - everything on the surface seems good to go - drivers for Nvidia were scrubbed, fresh install for AMD etc once all older drivers and software was purged. Stress tests in timespy(etc.) went smoothly, all without any issues, GPU temps at max utilisation were no more than say 65C or so.
Enter today (day 2 of having the card installed and first test in some actual gaming) - the GPU boosts to 99%/100% utilisation in game menu's - it drops down to say 50/60% during gameplay but anytime I am near a menu, an installer or even the options menu in game, it freaks out to 99+% usage, fan curves go nuts, temps stay within the aforementioned 65C which I am not worried about - my question is surely it cannot be normal for the GPU to be sitting at 99+% utilisation from just the main game menu or options menu in game?
For the avoidance of doubt - no other overclocks as of yet, literally plug and play and the only thing changed within Radeon software was a custom fan curve and the elimination of Zero RPM fan option. Baffled by this as the old Zotac 1070 never bothered itself in a simple game menu and its rather disconcerting that the card boosts just at game launch and actually relaxes once in game.
Any thoughts?
Base SPecs:
5900X
Crosshair VIII Hero WIFI (BIOS 3601)
32Gb G.SKILL Trident Z - 3200mhz
Corsair HX1000i PSU
Hello Everyone!
Any thoughts?
Base SPecs:
5900X
Corsair HX1000i PSU
Try loading up the GPU - they have a zero RPM fan mode for when they are lightly loaded.
However playing COD Warzone or Battlefield V I'm struggling to get out of the mid 70's in FPS when it looks on paper like I should be able to be getting 100+ fairly easily.
If you set vsync/gsync/freesync or lock the fps to suit the monitor it wont fly on the fps - do you get tearing? From memory in Warzone you had to toggle on the unlimited fps (Frame Rate Limit - unlimited) for example.
I've got a 165Hz 1440p monitor (only since last week) so I'll check those settings; I'm pretty sure in Warzone I've left it at unlimited though.
Struggling a little with an Asus TUF 6800XT OC card in terms of performance.
Most of the reviews and benchmark videos have performance at 1440p (and 4K) way above what I seem to be able to get out of the card and certainly at 1440p on par in the vast majority of titles with a 3080 (even a 3090 in some cases).
I had wondered if its my CPU (Ryzen 7 3700X) but its never caused me any issue before and in BFV/COD it doesn't appear to be using anywhere near the full CPU anyway (I am seeing more CPU related limits in MSFS since the last update though!).
Temps seem to be fine; I even wondered if it was the braided PSU cable extensions I used but swapping them back hasn't helped and the PSU (750W) seems to be more than adequate.
I'm just at a bit of a loss as to how I can find what's not working 100%!
You could see if this will help with Warzone, https://youtu.be/muSXmzm783s?t=243
