- 6 Dec 2007
- Cambridge
Yes always same keyboard and mouse.
I'm using either Nvidia overlay or afterburner
Sounds like a good suspect then - definitely try wired. Cheap and cheerful is fine for a test. If it solves the problem and you still want wireless, there's plenty of good 2.4ghz options.
I'd also agree about trying a minimal Windows build. Just create a new user profile and only install steam. Literally nothing else, then test an unmodded install of a game you know is showing the problems.
