Thanks just seen it, please tell me this has only been an option since performance update 5!Same way as you select any other plane, it's a separate entry. Same for other floats and ski equipped planes
Gonna hit me some waterways!
When hovering over a cockpit switch/control, I get a horrible arrow pointing to the direction of that control unless I'm looking directly at it. Does anyone know how to turn that off because I can't find a way to do that ?
Nope, works through the EFB setup just as before.When hovering over a cockpit switch/control, I get a horrible arrow pointing to the direction of that control unless I'm looking directly at it. Does anyone know how to turn that off because I can't find a way to do that ?
Thank you for your comments over the last 7 days with the recent Sim Update 5 release. We have seen and read from the core simming community and recognize there is some feedback that needs to be addressed. We have spent the past several days looking over it, reviewing, exploring the details and immediately started working on fixes.
As a result, a hotfix is coming in the next few days (target is Friday but could move to Monday) to address some of the issues as soon as possible. Here is a summary of the hottest topics we have seen in the forums.
Preview of Ground Texture/LOD in the Hotfix
- Volumetric Lighting is Missing – This was a shader bug and will be addressed in the upcoming hotfix.
- LOD Popping and Stutter when Camera Panning – PC Simmers with graphics set to Ultra will experience this when panning the camera around very quickly. We are working on a new option that will allow you to customize how much off-screen scenery will be cached. We are aiming for this to be released on August 24th (World Update 6).
- Low Resolution Ground Texture – This is a bug introduced when we fixed tree draw distance from high latitudes and will be addressed in the upcoming hotfix.
View from above 30,000 feet: Detail level will increase to an even higher level than Sim Update 4
View from above 30,000 feet: The same fix also improves the night lighting draw distance
View from above 60,000 feet: You can still see the photogrammetry of Seattle. The terrain level of detail is more than 1 terrain pixel per 4K screen pixel.
This is not an exhaustive list - we are investigating all the issues that have been communicated and we will give updates in the Feedback Snapshot on August 12. We acknowledge and apologize for the gap in our communication. Thank you again for your continued support and patience!
- CTDs – We are currently investigating and are planning on several fixes for World Update 6.
- Washed out Graphics and Cloud Appearance – Attempted improvements to the cloud appearance introduced an overexposure of the world. This will be addressed in the upcoming hotfix. We are planning on a brightness slider for an upcoming Sim Update to allow visual customization of your sim.
- Aerosoft CRJ – We have found and fixed a bug in an open-source math library that is part of Web Assembly [wasi-libc] which was part of the CRJ and has been resolved. A new package will be made available in the next few days.
- ATC Incorrect Altitude – The pressure altitude has been brought in line with the new altimeter simulation and ATC should no longer ask you to get to your current altitude if you’re already there. This is addressed in the hotfix. Further improvements to the altimeter and ambient pressure system will be coming in World Update 6.
- Temperature Spikes – The previous hotfix did not fix all cases of the issue. This is being addressed in the upcoming hotfix.
Sorry, I was answering your throttle question.
Second horrid?I’m grateful for the second horrid as our sim was beginning to look a bit Xbox with all the pop in but half of me wished they would just leave it alone for a bit so I can enjoy it as every update causes problems.
Yes, you’ll want those off.. they ruin the immersion. I’ve not got FS2020 open at the moment. However going from memory, in the Accessibility menu you have to select the ‘Legacy’ interaction method. There is also a further option in that menu to turn off the text labels.
Second horrid?
Nice to see that the visual quality has not been intentionally gimped and it’s being sorted this or next week.Im assuming either a Freudian slip or autocorrect from hotfix
Lol bloody phone, keeps making random calls too!Second horrid?
The white arrow not fading at the top of screen is a known bug. Sorry can’t help with the rest!Can’t get rid of the white arrow at the top of the screen or tool tips.
also my t300 pedals won’t map properly. Rudder deflects one way constantly. I’ve tried uncapping everything else and remapping the rudder axis. It seemed to work at first.
I have a VKB gunfighter and TWCS running too. Rudder works fine when assigned to the TWCS paddles
any ideas? Making me not want to fly.
thanks
