Don
- 20 Oct 2002
- Oxfordshire / Bucks
I have a Hydroshot with the soap bottle and it does a good enough job.
Do you fill the bottle with pre wash or do you mix it with water, in which case how much do you put in?
Google what a hydroshot is.... I own one and you would be better off peeing over you car than using, he need to get a wash mit on it wash it
I just follow the dilution ratios on the manufacturer bottle, I'm currently using polar by Autoglym as its a big 5ltr bottle
with a capful of old turtle wax zip wash from 2005
Crikey... I've worked out I've spent approximately £ 241.37 on detailing products since 2012 when I bought my first car.
Going by the car cleaning thread if you've not spent £1000 on the on-trend products you're not doing it right![]()
It's a car. Take it to a car wash. The end.
