Caporegime
- 21 Jun 2006
GDDR6. The lowest model to use it is the RTX3070TI,which you can see has not so great performance/watt.
Should hold up fine then. If not limit the power to 95% and it should give same performance after tweaking the core and memory as far as it goes at that power limit but much better in terms of cooling and noise
