I use a Sawyer water filter set up in a mavity feed arrangement, then I use a Steripen just to be on the safe side as I've been hit with stomach issues when camping in the past and it's never pretty. Since I've used that combination I've never had a problem, but a lot of people just go with the Sawyer water filter on its own.
My main water boiler is the titanium MSR Titan Kettle, I must have had it for maybe 14 years or so. They're not cheap but it will last a lifetime if you look after it. It perfectly fits a C250 gas cannister inside it with one of those tiny, titanium gas burner jobs as well. Tbh, I mainly use a Trangia these days so I get that and a mug and what have you inside the pot. There's lots of option on cooking system choices so have a look to see what others are using via Youtube and pick one that suits your needs and budget.
Backpack choice is probably the most important thing as having the right one makes such a difference to expedition enjoyment levels. I used to have a Lowe Alpine rucksack that was superb but just too heavy, so I tried the lightweight Osprey rucksacks, but found they all dug unto my hips, which is a known issue with Osprey rucksacks for some people. So I then tried a Gregory Zulu 65L backpack and it fit perfectly. It weights just over a kilo, iirc, I think the Lowe Alpine one was over 3 kilo, so quite a difference. Tbh, it's a hard one to answer really as everyone is different, obviously budget allowances too, but I would start with finding out how to measure your back and how the backpack should sit on your back properly, as it'll save you making a potentially expensive mistake. The thing with lots of compartments and features is they all add weight and weight is the enemy!
You want everything inside dry sacks if you can, different colours help you grab the right one easily enough.
Although a lot of people do it, the general advice is to not strap anything to the outside of your pack (if you can help it) as it can get you into trouble, catching on things, etc, plus you run the risk of something dropping off and you not realising. 65L is a good choice for myself, for both summer and winter gear - I hate knackering myself out on a morning trying to squeeze everything back in! - but people do drop right down to 40L or lower, but again it depends on what you want.
I'll stop there, I could babble on for ages about this sort of stuff
Edit: That Berghaus backpack looks alright, it's 1.7Kg which isn't too bad (just noticed that that's what my backpack weighs, I honestly thought it was lighter than that). The shoulder straps look a little narrow for me but they might be fine for you. That type of padding on your back creates big wet patches, which may not be something you can live with. Have a look at the back system on the backpack I have... (scroll down to the bottom) https://eu.gregorypacks.com/uk-en/z...0#pages=4&start=34&cgid=trekking-backpacks-40
