Caporegime
- 9 Nov 2009
- Planet Earth
and fans in servers etc generally run 24/7 for years and years.
No doubt mining will increase wear on fans, but to the point where it reduced their life enough to be signifcant? probably not.
Server fans tend to use different types of bearings which promote longevity over noise.Servers rooms,are anything but quiet and also tend to be temperature controlled to 25C,etc. People's rooms tend not to be temperature controlled,so lots of heat,high seasonal temperatures,etc has more of an effect on things running 24/7 as the fans will need to ramp up.
A lot of consumer stuff actually uses rifled/sleeve bearings as they are quieter but will wear out quicker. This is why the AIB partners don't give long warranties on their mining GPUs.
Since I have used constant speed fans in SFF builds,I have tested this out. Its surprising how some well rated "quiet" fans,start to wear quicker than you think,especially with dust buildup and they get appreciably noisier. In fact its why I have rated some of the old Noctua/NMB-Mat fans in the past because of their consistency.
