Make sure to regularly check your screws and bolts on this bench. I literally had bolts falling out of mine on the silver plates on the side from regular usage. Bulldog gear stated this was normal.
Will do. It's usually good practice to check any bolts/screws on gym kit occasionally as they do work a little loose. My concept2 rower states in the manual to recheck the bolts.
my only complaint is the adjustment for the front seat slider (horizontal not tilt) is screw fit where the rest of the bench is push pin.
I find that I only need to do turn the screw a couple turns, the push pin part holds it really well. Especially on flat, I've never needed to screw it in.
