- 13 May 2003
Put a brace on the treehouse door as it had sagged badly then re-hung it. Cooked a roast dinner and settled into a few beers.
Replaced two radiators in the kitchen which should be a simple job but those sort of things never are and it took hours. That said, the new rads look far better than the old ones which had been painted who knows how many times and the wall behind is now also painted the correct colour.
Rads on Flexi pipes...go on...Boils my blood when people don't remove radiators when they paint, I can understand it if it's full on copper pipes but 9/10 it's those Flexi pipes!
I swapped mine from something daft like a 1100 to a 1095 and was bricking it. Luckily the pipework had just enough play to make it work. I double lucked out as it was half the thickness too.To be fair mine were on plastic and it does make easier to get them on and off. The issues when replacing rads is that they are always slightly different dimensions between brands despite being standard sizes.
Never seen a rad on flexi pipes![]()
Got the rad out and started to sand the wall down before realising the paint (and large chunks of plaster) was no good. Ended up scraping to where it was 'good'. When I moved in a trickle vent was letting water in so I imagine that (plus the fact it had a rad far too close to the wall) contributed. Plan to fill, sand, PVA and paint.
I'm at the point in the job where you ask yourself "why did I start this?"
At least quote the post where I had finished the decoratingLike that exposed brick and shutters. Was thinking of shutters. But they are damn expensive!
I agree shutters are mega bux but these guys were actually inexpensive at £210 (and the ones in my bathroom) - from Blinds2Go no less. Obviously depends on your window size. Don't bother paying someone to fit them if you are mildly DIY literate.
The other one I used was California Shutters who IIRC had a gimmick that they supply B&Q. Often had voucher codes or "new customer" type pop-ups.Yeah same place I was looking at actually.
Would be looking at 2 windows each about 2.5x-3x your size.
And yeah absolutely self fit. The fitted places.. The prices are ridiculous!
Yeah the ones I ordered from California Shutters and Blinds2Go were identical.We had shutters put in 3 rooms at the front. Got 3 quotes from 3 companies and they were all within £15 of each other. Turns out, because they all get their shutters form the same factory in China. Including Hillary's and 2 local places.
Sounds like a level on Crash BandicootPut plastic bird spikes around the top of the kids trampoline to stop the pigeons making a mess of it.
