Hi ianh, thanks for all the information you have supplied in this thread. I am looking at this laptop and just wondered how you are getting on with it now after a month or so of owning it? how does it perform when just browsing web doing office based tasks, ie is it quiet?
Can you guys comment on the panel used in this laptop what colours are like and is there lots of backlight bleedalso what are speakers and battery life like.?
Anyone able to comment on the 3070?
It's advertised as full fat, its cheaper than my A15 RTX3070 and looks to offer more power.
My girl is curious but not up on tech and I can't find anything but reviews on the 3080.
Any info greatly appreciated.
Can anyone confirm that the display screen for the Erazer X25 actually supports G-SYNC? It is mentioned in the Overclockers product information but I can't find confirmation within Medion's website.
Also, any comments on backlight bleed would be welcome.
You will only get all the options if you have a mux switch and it is set to use the dedicated gpu.
It's adequate, not amazing, certainly not bad, just OK.
Now checked after getting the Nvidia stuff working and there is NO G-Sync options available using the latest 471.96 drivers with this 1440p 165Hz screen. So I'd suggest yet another "miscommunication" between seller and store just like the "165W TGP of the 3080 GPU" from factory when in fact it isn't etc.
It's mentioned on a few other sellers websites too but having had a look at mine, as the primary display "card" is the AMD APU and I don't have a second display on hand to use, I can't force the Nvidia Control Panel to display the extra display options where G-Sync would normally be displayed (as the APU is still the primary card) leaving me with just a basic menu, so I can't tell unfortunately.
I know the top of the range version of the X25, with it's R9 5800HX CPU and 240hz display, definitely doesn't have it as reported by several testing sites.
Any luck enabling GSync with the new drivers?
Nope, no G-Sync yet on 472.12.
If I had to guess I'd say it will never get G-Sync either, just because that'd be my luck![]()
Do you have the 3070 or 3080 model? 3080 model did have a BIOS update so possibly it was unlocked there?
I've got the 3080 model with the latest BIOS - Nothing unlocked for G-Sync.
Ordered a Legtion 5 Pro since its on Sale - Will get the X25 beast and compare both before deciding to keep the better one!
How much did you get the pro for?
