Has anybody used LG CX (or other 4k@120hz TV) as a monitor with Legion 5 Pro? Have been reading about problems with possible bandwidth limitations to 32gb/s with HDMI 2.1
Will get my beast today or tomorrow.
With 10bit 444 chroma?I've ran games on my 55" CX at 4k@120hz with no issues at all. Had vsync on and off to make sure it locking at 120fps. Super smooth no ghosting etc.
So I got my Legion 5 pro. Everything seems okay, but first thing I noticed was some odd sound from right of the keyboard. There is obviously fan underneath and noise is more like bad bearing. I am going to open it tomorrow and see maybe there is something rubbing against the fan etc.
Or maybe it is normal, waiting for some feedback.
EDIT! Did dead pixel check, found frickin 8 dead pixels across the screen. This is going back!
Oh dear. That’s not good at all. You just eyeballing it or got a tool? I’ve just ordered a L7/3080 with the WQXGA so hoping for a quality screen with no dead pixels. What’s their policy on dead pixels?
I've got what looks like a tiny bit of dirt on my 5 Pro's screen. Think I can live with it for the price.
Just upgraded the SSD and ordered some CL20 DIMMs to replace the stock RAM.
Which ram did you go for? I'm looking as well. Was hoping to get some CL16s/3200mhz @1.2v but can't find any in stock. Ta.
I don’t think there are any CL16 3200Mhz that work with AMD CPUs as you need XMP to be supported and its not support on AMD at all as best I'm aware. The Legion 5 Pro will default to the JEDEC profile only.
This is what I went for:
Kingston Fury Impact KF432S20IB1K2/32 32GB
It's CL20 and dual rank (there is a single rank version ending B2K2.
Cheers Dave. I'll contact g.skill see what their take it.
I've not seen it mentioned being used on the 5 Pro but given it only needs 1.2V for 3200mhz it could potentially work. If their Jedec profile is slower than 3200mhz then I'd avoid.
The Kingston Fury Impact definitely works as a plan B but that is CAS20.
Edit:
If you Google the part number there's some info on Reddit saying they default to CL22 on AMD.
Again cheers. That was my worry. I have searched, will do so again. Can i ask a favour? When you get you memory will you post up your CPU-Z results so i can see what should be expected? If g.skill is going to 22 then its the KFI for me. Cheers.
PS: Is it the discussion from a year ago? Only I've also read the 5 series doesn't act the same as 4 series AMD laptop chips. I've also read that AMD is ready to open up memory profiles in BIOS for their laptops as well. Might be a game changer if so.
