- 25 Aug 2008
- York, UK
Yesterday I cleaned the pond filer out then built a couple of new flat pack units to finish the utility room off (that I originally started when we moved in 8 years ago
I was looking at the metal ones which are a bit less fixed than that wooden one, although size will obviously have an effect.Wow, that's very cheap - maybe a £12 eBay sail is compatible
Seriously that's less than a decent garden shed ...
Just pulled the trigger on this and came out at just under £3k (in their sale with £1k off) with the roof shingles
Thread here
https://forums.overclockers.co.uk/threads/which-wood-would-you.18921835/#post-34590563
There is no way that bloke is sitting comfortablyWow, that's very cheap - maybe a £12 eBay sail is compatible
Thread here
Yesterday I cleaned the pond filer out then built a couple of new flat pack units to finish the utility room off (that I originally started when we moved in 8 years ago)
I concur, I have certainly rushed those 'man jobs'....I could have taken a while longer for sureBlimey you don't hang around do you.![]()
I need some help.
so what would OcUK do? It’s a 1920s house.
blown plaster is not unusual in buildings of this age. Can you provide some photos? What to do depends on the extent to which you're seeing brick, and where in the building it is (onto an external wall vs internal wall etc). Assuming nothing too crazy going on then my approach is to get all the paper steamed off, make good plaster:
Build up local but deep plaster with bonding plaster. If large areas need doing this way you might need to source the right lime-based stuff to suit the age of the building. Then skim with polyfilla and smooth/sand to get the surface ready. Do not try to do bulk fill with polyfilla it will craze and shrink as it dries. Keep it for surface prep only.
Then paint or re-line with paper and paint to suit your preference.
