Pretty much exactly the same score as the 5950X.
I wonder what AMD's Zen 4 Raphael that would be an APU and won't increase the core count would do against that?!
I guess Raphael will be in the most optimistic case a 16-core with Navi 2 iGPU?!
@Robert896r1 , I think it was you that alerted people early on to Rocket Lake latency issues, how AL looking for you so far?
Nice single core score, but I suppose in respect to multicore, seen it been there for a year.
Guess what the processor
knows that the AVX3 of this CPU has been killed. The AVX2 consumes 250W, but it can be pressed at about 108 degrees with a single large frost tower without a buckle (just put it directly on the CPU). Medium and high-end water-cooled pressing is no problem below 90 degrees.
For the test, I used Windows 11, DDR4 3600 Gear1 for the poor, and the multi-core is almost the same as the 5950X next door, and the single-core is violent.
According to the previous revelations on the Internet, it is possible that the B660 BIOS of the x country x in my hand needs to be improved, of course, it may also be a bonus of DDR5? Anyway, after the official release, it will only be stronger.
Without the blessing of TVB (maybe it is really not), Pcore full core 4.9G, Ecore full core 3.7G, Guanxiao core full core 5.1G should be pediatrics.
This time it seems to use FIVR, which is the set of Haswell and HEDT, but it is not very confirmed. I will analyze it in detail next day. If it is really FIVR, then the temperature performance is still good. Also, the 11900K without the buckle is aimed at I went at 115 degrees.
In addition, Intel has prepared a dedicated Gear4 mode for DDR5 very intimately for us. As long as you are not afraid of delayed explosion, DDR5 10G is beckoning to you.
I just wanna see gaming RT benchmarks, all these synthetics are so boring and useless for me. That's the
I'm wondering if we aren't seeing gaming benchmarks maybe alder lake isn't good for games just a thought that's all.
These leaks I'm sure are pre-planed, its always the same apps in the same order these people leak numbers for like the have some kind of advertising deal with.
If one is going to leak something why kinda half ass it kinda leaving people not really knowing what its going to be like unless they just making **** up.
Suits me if true, means i can get better DDR5 as well in a year or so timeSomething tells me the scheduler for big/little cores on alder lake is going to be bad for games, or not that much of a leap over zen3
Thats the only reason I can think of why Intel is happy leaking all these dour productivity benches and not gaming ones
No gaming benches isn't good thought we may have seen some buy now .
What about the 4090/5090 though as some people like to keep the CPU for a few years and will upgrade their GPU in that time so while a faster CPU is not going to benefit now it may do in a few years time.Gaming benchmarks are not exciting, as everyone knows the outcome already.
The outcome is that in 2021, 4K is the intended/desired/best resolution to be running at, at which all CPU's are GPU limited, and will be for many years. Now this statement of mine will be attacked by those who like playing at below console resolutions of 1080P, 1440P and that are stuck in the past. They'll defend their 1080P CPU benchmarks to the end of time. Let them, they tend to be the noisiest and the type of poster online 10 hour a day refreshing every topic of concern to them.
All you need for 4k gaming, even with a 3090/3090ti will be a Zen3/10th/11th/12th gen CPU with 8 cores, clocked to moderate levels. You'll see no diference in FPS between any of them.
Even a 9900k will be perfectly fine. This pretty much sums it up to be honest.
