- Do you have quite a few rooms to do?
- Do you have kids or other commitments that make it harder to devote significant chunks of time to DIY? Is it easier to break projects down into small chunks and do a couple of hours at a time whenever you can fit the work in?
- Are your floors uneven? Our plank floors are all slightly different heights, and we found the hired belt sander only sanded an inch at a time on each side, even though the belt was nearly a foot wide.
Then you should seriously consider buying your own sander.
We initially hired a floor sander from HSS Hire, but it just didn’t work on our uneven floors. It also worked out insanely expensive – the hire charge was fairly reasonable, but we spent almost double that on sandpaper. Due to the design of the big floor sanders, the belts rip extremely easily and we got through LOADS.
So we did a ton of research and eventually bought a Makita belt sander and a DeWalt detail sander. You can read more about why we chose the Makita
here. We buy sandpaper for each sander on Amazon for significantly less than HSS Hire charged us. And we can use the sanders for as long or as little as we like, with no time pressure to get the job done by the end of the hire period. To give a cost estimate, we paid around £200 to do the first pass only of two rooms. We then paid around £300 for the two sanders plus approximately £20 in sandpaper per room to finish these rooms (two more coats), do a third room, and then the entire three storey staircase. So it’s worked out much, much cheaper for us to buy our own equipment.
