Deleted member 209350
The base spec is totally useable for like 90% of people buying these, will still be stupid fast
I think for most people even the macbook air with the m1 will be more than fine.
Just stuck an order in for the 14 Pro with the full cores and 1TB as a desktop replacement… let’s see how I get on with it!
Seems like more than enough even if the Max is there to tempt usSame here. Top tier pro processor, 32gb RAM and 1TB HD. Should be a monster.
Only thing its missing is an optical port.
Can anyone post the base UK HE prices for the 5 models (2 x 14 and 3 x 16) please?
rp2000
Seems like more than enough even if the Max is there to tempt us![]()
snipped images
Sad bit is that they used to have optical ports (combined with the 3.5mm) but dropped it in the last redesign.
If you can wait the edu store is usually cheaper than Apple direct (don’t think they are an ocuk competitor right so I can mention them)Many thanks. Straight up 10% discount across the board.
rp2000
The images are from the UK Higher Education Discount Apple site. I'm not sure that price can be beaten unless you're a large enterprise customer.If you can wait the edu store is usually cheaper than Apple direct (don’t think they are an ocuk competitor right so I can mention them)
rp2000
Bought a MPB16 from them once on Black Friday. There was an extra 10% off their already low prices!Thanks both, never seen that one before!
rp2000
I have a 2018 13” MBP here with quad core i7 costing me £2300….
