Yes, they have been for years.On a related topic, are things like GMail or Outlook emails permitted for forum registration emails now?
Mine has asked me to re-sign in a couple of times today (since the 2fa force).Done 2FA was simple and easy.
Do we really have to resign in every 30 days?
On top of that, please can you get whoever does the website to have the input field correctly set up as a number input for mobiles so that phones show the number pad when you click the field rather than the standard keyboard
No leaving posts5 attempts to login and the ‘backup codes’ didnt work either. Not sure it worth it anymore. Have to resign in every 30 days? Its easier not to tbh. I cant find anywhere in my account setting to delete my account
I've had it enabled for a while. Is there a way to stop it logging you out every 30 days to ask for a new code?
Is the 30 day limit to the login token only if you haven't had any activity in that time? If so that's pretty normal, although maybe a bit shorter than needed.
Nope. I'm browsing the forums everyday and have to log back in every 30 days. Only takes a few seconds so no biggie though.Is the 30 day limit to the login token only if you haven't had any activity in that time? If so that's pretty normal, although maybe a bit shorter than needed.
Oh no, I have to enter a code every 30 days - it literally takes a few seconds out of your day guys![]()
Yes but for someone who is on a desktop PC in their own homes is a little annoying!![]()
Although correct, it's fairly quick to do, I'll be surprised if in 60 days or so you don't reverse that decision.It barely takes 20 seconds to log in every 30 days. Hardly annoying.
Reverse the decision to force users to use 2FA? No chance.Although correct, it's fairly quick to do, I'll be surprised if in 60 days or so you don't reverse that decision.
Dissagree, I go for the simple life.It barely takes 20 seconds to log in every 30 days. Hardly annoying.
