VR upgrades for DCS
18 Jan 2010
Lichfield
Hi all, wishing to pick the collective mind here if I may...
Currently using a lenovo explorer for simming (DCS/PC2/AC/DR) and whilst it's a good comfy headset with relatively clear visuals I'm having to crank steamvr resolutions to get the clarity I'd like which then gives a performance hit. I'm using 150% global steamvr resolution and 240% application specific for DCS which should give a combined total of 360%, on top of that I add MSAA in DCS to just take off the edges.
With the VR preset in DCS + steamvr resolution I can pull 50ish fps in the A10C instant action, bumping textures/shadows/view distance/MSAA drops this down to 45ish. I run the headset at 90hz with motion smoothing off in DCS, fortunately I don't seem to suffer from VR sickness.
CPU is Ryzen5 3600 @ 4.4ghz on all cores, gpu is rog strix gtx1070 @2101 core/8950 memory, 16gig 3200ddr4.
Ideally I would upgrade to a 3070 or the like but I can't justify the current market price, alternatively could I upgrade the lenovo to a reverb and use the higher resolution display to reduce the requirement to bump up the steamvr supersampling to achieve picture clarity? Even running at half resolution I believe it would be better than the lenovo and if the frametimes allow I could try full resolution with a steamvr downsample.
Anyone able to offer input?
Even better, anyone near Lichfield with a reverb willing to let me test it out? :D
TL : DR better to use steamvr supersampling as a crutch for low resolution VR display or use a high resolution display from the outset and downsample to allow the GPU to catch up?
16 Jul 2010
You won't be able to get the most out of the reverb with a 1070 (heck, it stresses 3090's if you crank everything to max), though you could undersample and get the benefit of massively reduced screen door effect, but I'm not sure how good that would look.
OP
18 Jan 2010
Lichfield
To be fair, the screen door on the lenovo is very good, I never see it. Running at native resolution is ugly and whilst I can supersample up till it's not, I think that's imparting some blurriness.
I know that the 1070 likely never hit 90fps with the full resolution on the reverb but I'm fairly comfortable with VR fps down to 35 or so and more than happy to be sitting at 45-50 so it might be useable, ideally I just don't want to drop the cash on it to find that it's not a workable solution :)
Man of Honour
Man of Honour
23 Dec 2002
London
As a short term assistance, go grab AMD FSR. Works with DCS assuming that you’re using OpenGL. I get a decent frame rate improvement from that with little visual impact
OP
18 Jan 2010
Lichfield
Ah yes, already using FSR, forgot to mention that one :D
Currently running at 0.7 renderscale and 1 sharpening.
FWIW I'm reasonably happy with the performance of the 1070 in DCS, just questioning if I could get a better image quality more efficiently by changing the lenovo to a reverb.
13 Jan 2018
From my understanding having a better headset resolution is less computer labour intensive than having a low resolution headset and cranking up the supersampling to match.
14 Sep 2008
Nottingham
I'll testify to that from a practical pov. While i can easily get my G2 blowing smoke cranking it up in certain games, the Index @150/200% will spin up my system in even the mundane applications like Big Screen and Pinball. In comparison in both those cases the G2 doesn't stress either my card or case fans.
OP
18 Jan 2010
Lichfield
That's sort of the way I'm leaning, gives me a bit more of a justification for the expenditure!
The index resolution is only slightly above the Lenovo so apart from the frame rate (120 vs 90) they shouldn't be too different in terms of horsepower required to drive them.
Do you run the index at 90 or 120?
14 Sep 2008
Nottingham
144.
But realistically it's only really used for Beat Saber and other rhythm games that aren't too demanding, as well as few games that aren't compatible with the G2 controllers. The Index is far less demanding and will live happily on a 3070 whatever the game. The biggest jump from the Lenovo will be the FOV, it'll be a huge increase from a the binocular small form a 1st gen WMR device, it'll seem cavernous in comparison.
That said it's a tough call to purchase an Index right now, certainly in a world where a better headset exists if your primary use is in a detailed simulation like DCS.
OP
18 Jan 2010
Lichfield
Ah I wasn't considering an index, my rig is in a 43" square walk in cupboard* I play exclusively seated and other than sims only HL alyx and skyrim VR (use razer hydra rather than WMR controllers). As nice as it would be to have the index/controllers etc. I just can't use them due to space.
A controllerless G2 is 440 quid at cex which is sorely tempting.
*a bit like harry potter, except with a TM warthog, TM rudders, 599xx TX wheel, T3PA pro pedals, home made shifter & handbrake and cobra bucket seat :D
1 Dec 2009
As far as I know just changing to a higher resolution headset means less screen door effect, though may give better blacks/contrast depending on panel type.
The clarity depends on the ability of your GPU at rendering at the required framerate although this ability must also depend on software renderer, similar to using Vulken instead of DirectX (WMR vs Oculus runtime).
This is how I understand things.
The Reverb for me gave better clarity than Quest 2 but that was really just due to the USB compression thing. DCS looks lovely and sharp now but I personally would not recommend G2 unless I had 3070+ to use it properly in that sort of game
OP
18 Jan 2010
Lichfield
Well I accidentally bought one, I'll report back as to how bad it is :D
And after three days of waiting for a dispatch notice from cex I get an email saying that they've cancelled the order because they can't find the stock...
To eBay I guess, shame I don't have MM access to have a peruse :(
21 Apr 2007
you're going to need more GPU grunt than a 1070 to drive an HP Reverb G2 I'm afraid, I'd upgrade that first if I were you which obviously isn't ideal given the market conditions its probably a waiting game if you want any kind of good value option a 2nd hand 2080Ti maybe?
OP
18 Jan 2010
Lichfield
I'm planning on running it downsampled till I can upgrade the 1070 (1060 is recommended for half res iirc). Currently running halflife alyx at higher than reverb supersampling (2400 per eye) and it's bobbling along quite happily at 75-100+fps with the Lenovo. DCS I have supersampling set to 3000 per eye and still get 45+fps with reasonable settings. Appreciate that HLA does dynamic resolution stuff in the background but I have yet to see any evidence of it or drop in visual quality.
I'm not playing any high speed games where low frametimes are essential and I don't have any issues with low fps with motion smoothing off.
I grabbed one on eBay which should arrive tomorrow, I'll see how bad it is but if theory holds true I may be able to run the reverb at 100% and get reasonable frametimes. I could be theorising crap and I'll come back with feedback for you all to chortle at :D
21 Apr 2007
there's no theory involved, it might be you can tolerate high latency and low frame rates but the simple facts are no way in a million years will a 1070 properly drive a Reverb G2.
I went from from a 980Ti (which when overclocked is a 1070) to a 3080 and I can tell you even that requires heavy compromises in DCS VR
on a separate note thou very pleased to see the Apache module now for pre-order on DCS, hell yeah that's gonna be so awesome
OP
18 Jan 2010
Lichfield
Ah yeah I have no illusions that it's going to be full speed, full res with the 1070. I will upgrade the GPU when prices settle* but for now I'll wind the G2 down to workable levels.
The stock 1070 is recommended for half res, mine happily runs at 2100/8950mhz which is 12-15% over its standard ROG binned boost so I'm reckoning to realistically aim at about 70% scaling and see where it goes from there.
*Happily pay money for hardware but not pay over the odds for hardware artificially raised due to shortage.
19 Dec 2010
Me too, but, I am close to breaking point and if I can bring in some extra money over the next few weeks, I think I will be buying a new GPU over the Black Friday/Cyber Monday weekend.
21 Apr 2007
Yeah I completely get it, GPU market conditions are awful for PC gamers atm, compounded by less than desirable options since Pascal era. Lobby your MP for financial regulation on Crypto that should free up the GPU market :)
