Planted most of the first 7kg bag of Daffodil bulbs in the small, side, front garden
Remaining bag and a half to plant tomorrow ....
Cheers - I think so, yes, should be fine before the frosts
yep, do u think they will regrow or is it true they only grow once?
I had some success earlier this year but when trying to find them bulbs etc and the ones I did find
they were really tiny
not sure how they would regrow in the ground
Wouldn't it have been better to remove the weeds firstSpent just over three hours and around 70 odd barrow loads of woodchip moved round to the back garden.
Before
The woodchip
After
Yes now is the time to put them in and they should regrow for several years. Just make sure you put them in nice and deep (thats what she said). You can either dig a hole and put 4-5 in one group or use one of those tools the other guy posted which does a smaller hole, depends whether you like a row of them or small groups of them togetheryep, do u think they will regrow or is it true they only grow once?
Arghhhh the bouncing pellets of doom!Exploded a pack of coffee beans everywhere, FML.
(FYI here is what a half-mil kitchen looks like where I live)
Outside paint is wierd like that. We (i) did our fence a a few years ago in a brightish orange colour but it's heavily faded. I'm quite liking the dark gray some people have gone for, but I can't bring myself to paint them again.Also, painted the shed. The previous stuff seemed to have ... washed off... in certain odd places. I have some rot on the back as well which I need to replace a single length of wood (is that easy enough to buy?). Garish colour, definitely not what it said on the tin.
Yes now is the time to put them in and they should regrow for several years. Just make sure you put them in nice and deep (thats what she said). You can either dig a hole and put 4-5 in one group or use one of those tools the other guy posted which does a smaller hole, depends whether you like a row of them or small groups of them together![]()
