Not all of them, mine is from 19th and not approved. So depending on something.. name? Order no? No idea.Either way it's working now and approves orders placed on the 19th instantly.
Going by Reddit:
Step 1: re-add finger print and keep an eye on the screen, the scanner location moves around, also scan the sides as it tells you, basically scan to the instructions. Add 2 scans of the same finger.
Step 2 : disable animations, settings - accessibility - text and display - remove animations
I don't know if the animation part is a Placebo but it feels snappier when unlocking.. of course you miss all those lovely android 12 animations but there's a chance that something funky is going on with FPS + PIXEL 6 + ANIMATIONS.
Has anyone got
"NEWZEROL 3 Packs for Google Pixel 6 Pro, Screen Protector High-Definition Soft TPU (NOT Glass) 3D Edge to Edge Full Coverage Soft Protective Film for Pixel 6 Pro - Transparent" from the rainforest for their Pro.
They appear to install the same as the LK ones so wondering if they are the same! I've got the LK ones ordered but they won't be here til December 12th, these are showing mid November at the moment.
Same here.Not all of them, mine is from 19th and not approved. So depending on something.. name? Order no? No idea.
Have you checked your spam folder?Not all of them, mine is from 19th and not approved. So depending on something.. name? Order no? No idea.
Same here.
Free them from plastic pain
NatWest App user here .. not a problem at all with my Pixel 6 . Have they done the software update at all ?Guys, my friend just picked up a Pixel 6, really nice phone but he can’t get the NatWest app to load, anyone having the same problem ?
Can we start claiming for the headphones today?
Yes I had same issue yesterday, I uninstalled and reinstalled and it worked again. I think it was because I still had it running on my P5, and then wiped it before selling at the weekend. Somehow that triggered some security alert, same with my Virgin money appGuys, my friend just picked up a Pixel 6, really nice phone but he can’t get the NatWest app to load, anyone having the same problem ?
Scratch that, issues still intermittent.After having zero issues with the fingerprint sensor all of a sudden it's taking two or three attempts to login. Only setting I can think of changing is turning adaptive brightness back on. I've reverted back to full brightness and the sensor seems to back to good.
Maybe someone else having issues can try this out to see if there's an improvement or if I'm imagining things.
