You can't use UK credit on other stores.
I'm using a debit card, not credit.
Have you tried deleting and adding the card.but using an icelandic address for the card? Worked for me. Use a 3 digit post code liek 107, you can make the rest up. I just used my actual street but said I was in Reykjavik and postcode 107
Thanks, that sorted it!
I'd probably be able to notice more differences if I compared images of both games, despite the different scenarios, but I'm not going to do that, I'm just going to play.Just had a quick blast, looks gorgeous and buttery smooth![]()
60 fps over a slight improvement in quality all day long.
Been playing FH5 on Series X this evening. It's great, I've been really enjoying it and playing in performance mode - it looks and runs great.
But... I don't really see the graphical leap from Horizon 4 which was also 4K 60fps on the Series X. That looked and ran great too and really FH5 is just more of the same. I'm fine with that, it's all I expected, but if anyone is expecting a big leap graphically over Horizon 4 I think they'll be disappointed.
Or maybe I just need to play it moreI'd probably be able to notice more differences if I compared images of both games, despite the different scenarios, but I'm not going to do that, I'm just going to play.
12:30pm finish in work then straight on it, couldn't be assed to switch region to play it earlier last night.
Is it me or does quality mode feel lower than 30fps?
Every comment I've seen saying it feels like 60fps and that the developers are wizards.I only played FH4 on Seris S via Gamepass (it was an optimised title).
I don't recall any performance/quality mode options so just wondering what fps did FH4 run at on the series S?
Planning to fire up FH5 after work today.
rp2000
Cool,FH4 was the same as FH5 is - 1080p60 only.
Cool,
So I will pick performance mode then, to get 60fps on FH5.
rp2000
