- 27 Oct 2008
- Gloucester
Set minimum test duration to "off"Whats up with cinebench 23 is there no way to run the test once and get your result ? Why is it looping like 10 times?
My long reign of dominance will come to and end, finally. At least for a few months anyway.This should get v tasty tomorrow and onwards!
Oof, what did you get? I had a 1717 score that I didn't post as the thread never got updated.Well it would have been over if I bothered to post my score lol
+50 boost alone doesn't get you thereI've had a go with R23 and I wonder what is your secret!
With PBO +50 Boost,
1669 Single
30421 Multi
Well said.+50 boost alone doesn't get you there
Need to play around with curve optimiser
and have certain amount of silicon lottery luck, so that best designated cores could take a much lower curve
And, probably, a very clean Windows install.
Well done. You need a excellent sample to be able to do an all core -20. I have a few cores that wouldn't like that.Windows is stripped down with minimal background tasks and av disabled. I'm using a -25 all core curve. -30 tends to black out the moment a test finishes. Setting the boost higher than 50 looses a few points maybe due to having to throttle. I'm using a 280mm AIO so I don't think the single core test at least is being held back on this cold day. All the various security updates might be playing a part as well giving different results from a year ago.
Let's see some 12900k
Absolutely, i'm amazed that peeps havn't been pumping them into this thread already. That said, @humbug has said he won't be updating the thread. That's a shame to be honest because over the next year or so we can all see the swings and roundabouts before our eyes if it was updated.
Should be easy enough for anyone interested in it. Copy paste your OP and carry on. All you have to do is get a mod to lock this one and change title.Some may have noticed i haven't updated this thread since April.
I don't have as much time as i used to and its feeling like too much of a chore, Sorry.
Feel free to make your own.
