I actually bloody love that Spyder, Porsche seem to be growing on me. I've never really been drawn to them as the looks just don't do it for me, but I've always respected the fact that they are proper drivers cars. Every petrolhead should own one
@Gibbo, would you mind if I send you a trust message about V8 Vantage ownership? I'm looking at buying one as a toy for the weekend but had some questions and you've got a solid example so probably know everything I'd be looking to find out![]()
That is fine mate, but maybe make a thread on the forum as their are a few Vantage owners here and mine has not caused any trouble so regarding running cost I cannot add much really apart from expect around 22-25mpg on a cruise and around 15mpg typically, tyres fit Michelin PS4S, service with a specialist, I use AML and a full service is £500-£750 per year dependent on what is required and if your not using often then you can service every couple of years. Brakes are quite expensive been two-piece items, about a grand all round if memory serves me right.
Mine has been trouble free, its a 2009 4.7 manual with under 30k miles, done a few thousand in my ownership, they can be driven all year round but they are prone to rust on the underside so I would avoid using on salty roads and an underside inspection on any purchase is a must to ensure its rust free. I have contemplated selling mine but right now I don't need to free up the cash and the values continue increasing on the manual 4.7 cars as they are the ones to have.
A test drive might put you off, it is the car you need to drive for at least an hour or two before you can gel with it, once you do get that gelling as to speak the things you dislike in the first five minutes, namely the heavy clutch and clunky shifter you adapt too and you forget worrying about them and start to pick up on how magical the steering feels (hydraulic) and how much communication is sent to your bum and how well balanced the car is been a transaxle layout and the noise is just incredible as long as you pull fuse 22 or wire a switch to that fuse as I've done so I can operate it on a switch though in all honesty for me the exhaust valves are always open. It sounds magical pootling along and sounds incredible at full chat, the engine will pull and rev linear right to 7000rpm but there is not really much to be had for passing 6000rpm.
The engines are noisy on these cars, clatter a lot, tick a lot and can sound broken, I had mine investigated both by Aston Martin and a specialist to confirm nothing was wrong, its simply dry sump noise as it is quite a complicated engine, even an oil chance is not simple as it has like three drain points.
Find one, get it inspected and if it passes buy it, they are magical and make great weekend car and can be used fine as a daily, just avoid salty roads if you want to keep it long term, the handling is very good the car just has a steep learning curve and it is a heavy car so they are not the fastest car neither do they feel fast. But do you feel like James Bond driving one? ABSOLUTELY! People really admire it and mine is not a bright colour but people love Aston and it is a very special car to own and drive. Certain marques have a very special feeling and Aston has it.
Any questions feel free to ping me but my advice is make a thread, keep it public to help out future people making the same consideration.
If your ever up this way you are very welcome to come see mine, I will happily take you out just give me plenty of warning as I've SORNED it for Winter and its sat in the garage keeping dry and warm.
