15 Nov 2021 at 18:03 #601 Unseul Unseul Soldato OP Joined 18 Jun 2018 Posts 5,057 Location Isle of Wight I'm happy with rec room or minigolf.
15 Nov 2021 at 18:09 #602 ShiWarrior ShiWarrior Don Joined 20 Oct 2002 Posts 34,605 Location Oxfordshire / Bucks paint ball ?
15 Nov 2021 at 18:10 #603 ShiWarrior ShiWarrior Don Joined 20 Oct 2002 Posts 34,605 Location Oxfordshire / Bucks Go Karts ?
15 Nov 2021 at 18:35 #604 Ravenger Ravenger Soldato Joined 16 Jul 2010 Posts 6,816 I'm happy to get Demeo if others want to play it as it now has mid campaign saves.
15 Nov 2021 at 19:01 #605 ShiWarrior ShiWarrior Don Joined 20 Oct 2002 Posts 34,605 Location Oxfordshire / Bucks Ravenger said: I'm happy to get Demeo if others want to play it as it now has mid campaign saves. Click to expand... if we get this, is it cross play ? https://www.oculus.com/experiences/quest/3634830803298285/?locale=en_GB https://store.steampowered.com/app/1484280/Demeo/
15 Nov 2021 at 19:04 #606 Ravenger Ravenger Soldato Joined 16 Jul 2010 Posts 6,816 Yep, it's cross-play between all supported headsets.
15 Nov 2021 at 19:09 #607 ShiWarrior ShiWarrior Don Joined 20 Oct 2002 Posts 34,605 Location Oxfordshire / Bucks ok, so i would get it from Oculous so i can play without PC or with PC?
15 Nov 2021 at 19:11 #608 Ravenger Ravenger Soldato Joined 16 Jul 2010 Posts 6,816 It's cross-buy on Oculus so you get both PC and portable versions.
15 Nov 2021 at 19:12 #609 Ravenger Ravenger Soldato Joined 16 Jul 2010 Posts 6,816 I need to decide, Steam or Oculus? Hmmm... tricky.
15 Nov 2021 at 19:14 #610 ShiWarrior ShiWarrior Don Joined 20 Oct 2002 Posts 34,605 Location Oxfordshire / Bucks Ravenger said: I need to decide, Steam or Oculus? Hmmm... tricky. Click to expand... you've answered your own question above get the OC version, then you have both
15 Nov 2021 at 19:16 #611 Unseul Unseul Soldato OP Joined 18 Jun 2018 Posts 5,057 Location Isle of Wight Downloading demeo onto my quest 2. Figure we're probably not going to play for more than 2 hours unless it's awesome, so can always refund it.
15 Nov 2021 at 19:19 #612 ShiWarrior ShiWarrior Don Joined 20 Oct 2002 Posts 34,605 Location Oxfordshire / Bucks so we are getting it then, ok..
15 Nov 2021 at 19:20 #613 Unseul Unseul Soldato OP Joined 18 Jun 2018 Posts 5,057 Location Isle of Wight ShiWarrior said: so we are getting it then, ok.. Click to expand... Figured why not.
15 Nov 2021 at 19:21 #614 Ravenger Ravenger Soldato Joined 16 Jul 2010 Posts 6,816 I'll get Oculus, as it makes it easier to party up.
15 Nov 2021 at 19:24 #615 ShiWarrior ShiWarrior Don Joined 20 Oct 2002 Posts 34,605 Location Oxfordshire / Bucks its only about 800 Mb on the Quest 2, downloaded it in 60 seconds lol
15 Nov 2021 at 19:25 #616 ShiWarrior ShiWarrior Don Joined 20 Oct 2002 Posts 34,605 Location Oxfordshire / Bucks Ravenger said: I'll get Oculus, as it makes it easier to party up. Click to expand... thats true, good point
15 Nov 2021 at 19:26 #617 ShiWarrior ShiWarrior Don Joined 20 Oct 2002 Posts 34,605 Location Oxfordshire / Bucks PC version is 1.5Gb figured it would look much nicer on the PC so i will have both tonight via Quest 2
15 Nov 2021 at 19:29 #618 Unseul Unseul Soldato OP Joined 18 Jun 2018 Posts 5,057 Location Isle of Wight I'm ready to play to be honest, if the rest of you are.
15 Nov 2021 at 19:30 #619 ShiWarrior ShiWarrior Don Joined 20 Oct 2002 Posts 34,605 Location Oxfordshire / Bucks 2 secs
15 Nov 2021 at 19:33 #620 melmac melmac Soldato Joined 19 Dec 2010 Posts 12,692 I will make it tonight.
