the only reasonable conclusion to draw is that Jono doesn't believe Rittenhouse acted in self defence
Not lawful self defense no.
he's made up his mind and no amount of evidence is going to change it.
Jono is on the chaos, dysfunction, and degeneracy end of the political spectrum. He’s just defending his team.
The moment he turned around there was less than 2 meters between him and Rosenbaum, which is why Rosenbaum lunged, at most he could maybe have run for another few meters tops..
Again though - WHY?
If we're assuming he's exhausted the fleeing option then what is the argument?
Hmmm that's a reach. It's pretty strong evidence - Kyle stated he grabbed, it, the forensics back that up with the residue on his hand, the main witness/journalist nearby backs up the claim that he lunged at Kyle... Do you think his hand accidentally fell and wrapped itself around the end of the barrel then?
That's essentially the crux of your responses.Seriously WTF?
What kind of nonsense question is this? "assuming we take you argument out of the equation, what is your argument?" Just lol.
That IS my argument. Again, you are incapable of or just refusing to follow the point I'm making.
"thats a reach" / "thats dubious".That's essentially the crux of your responses.
The forensics back up that he got his hand at least near the barrel as it was fired (due to the soot). That is all. There is no proof he actually did touch the barrel.
watch the video again, but do try to do so without your preconceived biases. There's less than 2 meters between them, rosenbaum is clearly faster as he doesn't have a gun in tow and hasn't run a good 100+ meters whilst holding fire extinguisherThat's just obviously false.
He was clearly quickly catching him and couldn't continue any further without giving up his ability to defend himself.The difficulty with the first killing is that he does stop running even though he still can continue.
Eh? You were literally asked that, why didn't you just answer clearly? And yes it is rather hard to follow the point you're making when you won't answer basic questions but instead resort to deflection. I literally asked you back up here, look at your response to that...
https://forums.overclockers.co.uk/posts/35247428/
If your only objection re: the use of force is that he should have run a bit further then why not just make that clear - you believe everything else is reasonable just that in your mind he could have kept running.
Well, it is a reach... but either way the claim re: the "only fact" is still flase even if we assume your interpretation to be true.
The anti-Rittenhouse outside of court are stupid.
The 20-year-old male suspect, Anthony Chacon, has been charged with felony bail jumping, misdemeanor bail jumping, battery, resisting and disorderly conduct, Sgt. David Wright, a spokesman for the Kenosha Sheriff’s Department confirmed.
A second suspect arrested Wednesday, 34-year-old Shaquita Cornelious, is facing charges of resisting, disorderly conduct, and possession of marijuana, Wright added.
Bunch of loons
So you think he slowed down because he thought **** it, I'm just going to shoot this dude and not because he come to a corner had a bunch of cars blocking his wa?yyes i have watched it countless times now and its quite obvious Kyle slows down, turns (which is how Rosenbaum becomes so close) and then shoots him.
Bunch of loons
I don't think he knew what he was doing. I think he panicked and ended up using reasonable force on Rosenbaum.
What would resonable force have been? Harsh language? Maybe a stern finger wagging?I don't think he knew what he was doing. I think he panicked and ended up using unreasonable force on Rosenbaum.
