- 19 Aug 2019
thanks!110v is usually for the pros working on site, safer voltage incase something goes wrong, it also requires a transformer. 220v is fine for home use.
I ask myself that about 50 times a day. But I don't think I've damaged it so much; I just think that I don't know what I'm doing. But I'm learning and I'm enjoying that part.
Also, the quote I got was for about seven thousand pounds.
I suspect I'll have it all done professionally if I ever get the works done to the place that I want to.
There might be some at Lidl still. They were out a few weeks ago. But, damn - doing a whole floor with it will kill you. And it'll be awful.The drum sander has not worked out;
Here is a video explaining why.
I am now in the market for a belt sander.
There are two Makita 9403's one is 110v and the other is 220v. Dumb question but in the UK does it matter which one I get?
Your videos are great! Please keep making them, when this is finished how about you do a new roof or similarThe drum sander has not worked out;
It's not going to look like that - that's fresh wood. Certainly not for any period of time at least.From the look of my floors can we determine they are, indeed, pine?
I'm trying to find out how to finish them.
I want them to look like this:
The belt sanders can be a bit of a handful the first time you use them. From your video it looks like you've gone against the grain/not with the flow of the boards. Is there a way on the underside to adjust the sandpaper so its not so abrasive.
I used one years ago for my parents and didn't find it too bae once I got going. Nails sticking slightly proud ripped the sand paper but it wasn't too bad. I only went with the grain/direction of the boards, then used a big handheld orbital sander for the edges. That was quite tricky to tame but worked well.
Keep going pal, don't give up.
thanks!
Slow growth as opposed to long, in a way. Length of growth is just a function of (how fast can it grow x how big do you need it)That is nice wood. It had probably grown for 100s of years, where what you buy in the shops is probably 20 years old or something. They longer it grows, the better it is I think (are we still talking about wood?).
Can't pull them up. They're 6 inches in depth!Whilst you were pulling them up I think I would have just replaced them rather than trying to sand them.
