Well today it turned up.
What an absolute monster.
What, the bill...?
Aha, so a bit later on in the instructions you actually remove these 2 bottom NVME drives, put the monoblick under them and then a second plate on the back, ok![]()
Just closed my eyes and entered the credit card information while sobbing quietly.
You do know that top M.2 slot shares PCI lanes, so the bottom x16 PCIe will be disabled and the top one will run at x8?
Ahhh man
Reseat it, and remove the BIOS battery for a bit and try again.
Re-seating no dice, 1 stick of mem no dice, all nvmes removed no dice, diff stick of ram, no dice. Battery remove, cmos clears no luck.
Thought id try one last thing, change the battery out.
We have life![]()
Yes, defaults with no overclock.
Vcore is up and down.
Vcore goes up to 1.34v with a 4.8ghz until the temps go up to 100c then throttles down to 1.15v at 4.4ghz in cinebench r15 cpu test.
When playing BFV my 3090 doesn't go over 50% usage whilst cpu is up and down with some temps in the 100c range.
