Do you need to auto-tune the PID due to replacing the hotend?
( Bearings/pulleys/cables/belts all not available from OcUK lol)Well... ordered most of the parts I need from AliExpress.... won't be here till Jan 30th though urgh( Bearings/pulleys/cables/belts all not available from OcUK lol)
And a few pieces form the rainforest. (GT2 belt fibreglass reinforced, and a set of pulleys).
Belt Driven Z-Axis with top mounted rotated motor. Going for 5 bearings across the top instead of only 4. I ordered enough parts for two kits in case I get another printer and want to do the same.
https://www.thingiverse.com/thing:4243512
Got mine setup last night but havent tested it out yet. Didnt think about longer stepper cable for the Z motor so that was a brainfart. Had to make one up last night and was late by time I had it done.
sure you will.Oh lord... about to buy a used Delta printer lol. EDIT: I failed, I got it. Will prob use it for rapid prototyping.
I'm totally sold on input shaping in klipper, amazing.
These are the results of the ringing torture test with 5,000mm/s2 accelerations.... Left is no input shaping, middle is manually measured input shaping, right is the fully automated calibration from today since my ADXL accelerometer arrived, not only is the ringing completely gone (faintly there still on the manual one if you look closely) but there's significantly less smoothing going on than in the manually measured one - you can see how crisp the edge of the X is for example.
Trying to be patient since I assume they are a smaller company.
Just started converting my Jubilee toolchanger to 4 x Orbiter extruders. Looks like it's going to halve the weight of each print head, meaning I should be able to crank the speeds up to close to where my big CoreXY is.
They are built using 3 different manufacturing processes. CNC machined aluminium for the tool plate, resin printing for the part cooling ducts (using Esun high-temperature resin), and FDM printing in ABS for rest of it.
"If it pleases the Crown...". I would love to see a video of the tool change in action once you get this beasty running.
Looks great so far. Really clean. I can only imagine the headaches must be getting everything aligned and calibrated between tools (offset etc).
