I'm honestly not sure how you're doing it. I gave 'the middle' as an extreme example. I think I can drag from 5/6's of the way over and it's still fine. I believe you're literally dragging from the edge and then yes of course... it will get confused with a drag from the edge to go back...
I'm not saying I don't ever do something like this, but when I do I usually realise and glide my thumb back over and release. I also then don't blame the UI, I realise I just had my thumb too close to the edge
I did a bit of a search for how big the gesture zone is and found this -
Honestly, come on. Surely those are tiny and if you're scrolling but start that far to the edge of the screen, it's not a UI issue?!
It's quite interesting actually. On the page that has that image there is some discussion that apps can exclude a portion of the edge from being 'back' so they can use it for their apps, but it cannot be taller than 200dp.
Wow I never kenw there was a home gesture area (serious) - thanks!
anyone else ordered the wireless pixel charger? £70 seems a bit of a bump but thought I might as well with my £60 store credit.
