- 19 May 2005
Cheers.
Mine wasn't working to start with. So long as you see the blue 'screen call' button when your phone rings, make sure you go into phone settings and then into voice. Mine started to 'activate' when I did that. The first time you use it, you have to be on wifi despite what it says.
not worth as much now you stuck your covid ears inside![]()
4g is no better for me..5g is beginning to **** me off, low 5g signal and no mobile data are bugging me. How do you make 4g the preferred speed?
Dial *#*#4636#*#* which will bring up a secret menu, go to Phone information and under "Set preferred network type" to LTE/TDSCDMA/GSM/WCDMA. Default is NR/LTE/GSM/WCDMA if you want to change back.
...fully understanding what they were saying even though and it speak and ounce of their language
This is the 5g issue my mate has, apparently if he loses 5g it just does not find a 4g or 3g network and sits there with no signal.
The live translate of text messages is so good and decided to try last night with a friend and was able to have an entire conversation with both of us fully understanding what they were saying even though and it speak and ounce of their language
Here`s hoping Samsung release a Snapdragon-based S22 early next year.
I received the below charger yesterday and gave it a quick test. I was on 60% when I plugged it in and it took 1h 20 to get to 100%, should I be expecting better or is this normal, it did say it was charging rapidly. The charger states it supports PD so I figured I should be good.
https://www.amazon.co.uk/dp/B0913BHL7V
It's £10 cheaper and comes with a cable unlike the official one.At that price why wouldn't you just buy the official charger.
It is pretty much if you want another cable as well for whatever reason.I only paid £25 for the official one, and the cable comes with the phone.
I could understand if it was half the price of the official one.
