NVIDIA GeForce RTX 3090 Ti, the flagship reinvented
HRL
HRL
22 Nov 2005
Devon
The heat will be limited to just the GPU side of the PCB, as only 12 memory modules on the 3090ti, so that should make things easier, but no escaping the need for exceptional case airflow.
I'm considering a 3090TI, though was hoping it would be less than 450W!
Really don’t know why it’s a 450W part. I’ve been running the VRAM on my 3090FE @ 21Gbps for the past year, albeit with 24 x 1Gb chips rather than 12 x 2Gb chips, but the GPU is hardly offering much more performance than the 3090FE, so why the need for an additional 100W? OC’d, mine can peak at 400W just, but typically it’s 350W or less.
28 Jan 2003
Bristol
Strange my 3080TiFE will sit at just under 400W when you up the power limit with no other parameters changed just letting the chip work within the uppped limit as it sees fit, so I would expect a 3090FE to do that more readily and the 3090TIFE to require 400+W more often too, to get it at <350w I have to undervolt.
25 Apr 2017
A pointless card which has no business lighting wallets on fire as Lovelace would be just 7 months away at that point and the 4070 is already going to beat 3090 Ti. Had they released this 9-10 months ago, I would have bought it
28 Jan 2003
Bristol
7 months away assuming it launches then and that you can get hold of a 4070, if its anything like my 3xxx purchase it wasn't until 12 months after launch when I was lucky enough to land one at MSRP, I am so glad I only sold one of my 1080s until I had one as I would have been stuffed, should this shortage situation continue you could be nudging 2yrs before you have one of the next gen at a reasonable price.
21 Jul 2005
Officially least sunny location -Ronskistats
The 4070 is going to beat the 3090ti? And what's your source for this information?
Its used on hypothetical massaging where because the 3070 was close to a 2080Ti on a generational leap, its apparently applied to anything now. While the 40 series might improve again, I would expect the obligatory 20-25% improvement - only the RT technology might be where larger gains can be had. I have heard that they will consume more power but lots of info to digest between now and then so we will see.
16 May 2012
I thinks nvidia regret two things about the 30xx launch. The performance increase over 20xx was too much of a jump, plus pricing of fe range was too low. Not in our opinion of course.
Which is why the 10gb 3080 fe is now eol. A 12gb version will be priced at 800/850. With the 16gb 3070ti taking on the £650 price bracket. Nvidia want to push up the mrsp so we don't gasp too much when the 40xx drop.
21 Jul 2005
I don't think the pricing was too low.
Turing didn't offer a lot and they layered up the pricing. This was before all this lack of components etc and they cant sidestep that one. Then they seem to come up with nonsense naming tiers with multiple flavours around the same products.
The 3080 is where it should be priced, between £600-700. This should be what you have to pay if your an enthusiast gamer type. They can offer nutter tiers above this for silly money as its then up to the consumer to pay for it. Now revisiting the entry tier, the 1050Ti was priced correctly between £100-150. If you start back there you could tower up a sensible stack.
Excuse what you like, a 3060Ti on a well known favourite dish name is regularly £800. That is a joke.
23 Oct 2019
there is nothing about 3080 being EOL, its been a rumour going for so long now yet we keep seeing 3080 FE drops.
16 May 2012
Reading the overclockers stock situation thread. Overclockers themselves are advising pre orders above a certain number to cancel as they are not receiving AIB 3080 stock anymore.
As nvidia supply fe cards, its reasonable to assume they will have the final stock of 3080's. Apart from occasional fe 3080 drops there is literally nothing about.
23 Oct 2019
i am not disagreeing mind you, but this rumour has been going even before the 3080TI is out.
16 May 2012
The only reason the 10gb 3080 could possibly be eol is one based purely on nvidia price gouging. Add two extra gb vram, tweak the cuda cores, then add £150/200 to the mrsp.
It's all about nvidia milking the 30xx until the 40xx has a paper launch.
21 Jul 2005
Very true. Although why are nvidia keen to offer larger VRAM models now it surely cant be just to excuse a price hike (temptation)?
