https://www.overclockers.co.uk/ek-w...gb-pump-reservoir-combo-acetal-wc-9ws-ek.html these are the pump/res i have i just want a way to see the correct pump speed via the aqua suite soft ware
Those are EK pumps, not Aquacomputer. So don't have Aquabus. You'll need to connect them to a PWM output (or DC voltage control) for controlling speed.https://www.overclockers.co.uk/ek-w...gb-pump-reservoir-combo-acetal-wc-9ws-ek.html these are the pump/res i have i just want a way to see the correct pump speed via the aqua suite soft ware
just dusted off and fitted my aq 6 XT
i have 2 ek d5 pumps do i controll them via fan pwm ports or wire them directly to aquabus? 15.2 in the manual states D5 pumps to be connected via aquabus
This all looks like it should work. Note that your selected fans can daisy chain together in series for ARGB control - many other fans won't have this feature if you should change model.Hi all, I posted this over on the Aquacomputer forums also but thought I’d ask here too. I am finally planning my controllers layout in my build using the aqua computer family of products.
I would appreciate any advice you guys can give me in planning the system and basically ensuring I’ve got the diagram / configuration correctly mapped out.
- The system will run a dual pump loop in series (2x D5 Dual Next)
- Three radiators, two with 6 PWM RGB fans each, one with 3 PWM RGB fans (EKWB Varder X3M Fans)
- Aqauero 6LT controller
- Hubby7 USB extender
- Splitty9 fan splitters x3
- Farbwerk360 lighting controller
This diagram represents how I think it needs to all connect together but would greatly appreciate any advice, pointers, suggestions, point out errors, etc
I haven't shown ancillary elements such as CPU block RGB, Flow sensors, or similar, this diagram (for now) is only showing the main elements.
Thanks all![]()
On the subject of making cables, can anyone recommend a good kit for crimping and wire creation for pcie/atx/usb/dupont cables? I appreciate these are different pin types and wire guages.
Thanks guys for the responses, that’s some great input.
I have a hard time trying to understand how aquabus works. I haven’t been able to find a resource that explains it clearly (AC stuff is awesome but the explanatory material is a bit skant!). Can anyone explain it in simple terms, or point me in the direction of a decent resource? Edit: to note I also have the Aquabus X4 expansion board fitted to the Aquaero
Thanks so much @Cenedd ! So should I use both USB and Aquabus then for all connections? For the pumps, I can accomodate that in terms of the "show build". All other items are hidden away, although I have to say I don't want to have to add more cables.
I am slightly unclear on your line: "If you plug devices in by USB, that lets Aquasuite (the software) communicate with them" : I presume Aquasuite can still see them via Aquabus if USB is not plugged in? In terms of communicating between devices, I can't envisage a scenario where I would need this, as in, I had understood the Aquasuite would read a temp input from a component, and I would have effectively programmed in a repsonse using the software (exmaple: water temp input controls speed curve of fans).
Or is this what you're saying about "autonomous" - if Aquasuite crashes, it doen't matter, as the aquaero can still control fan speeds based on temps?
Sorry for all the questions and if I'm not understanding but your help is greatly appreciated!
I have to admit: I've only built one computer before (in 2015) and it's a watercooled system with an Aquaero 5 or 6, but it's actually running without Aquasuite even installed on the computer - I replaced the OS disk on a total reinstall. It all still works to the last profile I defined in Aquasuite. So I must have set this up using Aquabus. Will have to check my old build log and look inside the case. I think it stores the profile on the Aquasuite chip, right?
So I might be answering my own question as it were...! Or, if I'm only referencing a temperature sensor, I am probably not using Aquabus at all. Just PWM connection to fans from the Aquaero. Will have to check later this evening.
