- 23 Mar 2011
The plot thickens :/ hmm thanks for the report!I have the LG CX and I get DTS showing in my Sonos app.
I think i should try it myself later and see what I get
Maybe it was patched
I do but it is not cabled up yet as I'm still looking for a HDMI switch. I get multichannel PCM for any HD soundtracks.Yeah but Chris you said you have the Arcana fury now.
The LG CX doesn't support DTS so you are bypassing this by going through that device.
https://www.google.com/amp/s/www.th...aybase-arc-amp-battery-saver-mode-13-4-update
"Users on Reddit who’ve tried out the functionality report that Sonos only seems to support standard DTS Digital Surround, so you won’t be able to get the most out of sources that use the higher specced DTS-HD and DTS:X formats. If you try and play DTS-HD, it reportedly comes through as regular DTS. The Sonos app shows a small “DTS Surround 5.1” badge when a speaker system is playing the format.
Other niggles you might need to watch out for are whether your TV supports DTS audio. LG’s popular CX and C1 OLED TVs, for example, don’t support DTS, which means you’ll run into issues if you’re passing DTS audio through them via HDMI. Sending audio directly from an external source to your Sonos equipment should work, though."
Odd. Maybe the Sonos app reads it as DTS but the lg passes it through as something else?
Weird.
See I'm on the fence about getting the sub too but not if this stuff will become an issue, it's a niche issue I'm sure
Maybe I'm confused with Atmos.Well no idea how you are getting the app to show DTS as the LG deffo doesn't support it.
Please excuse my ignorance on this topic in general but what's LPCM?The TV won't pass it through as anything it just won't work. If you use a Nvidia shield it will pass it through as LPCM.
There's just so much confusion surround DTS EtcMaybe I'm confused with Atmos.
Reminds me I really need to find a switch.
I love Sonos for its simplicity, my family can use it without having to toggle settings etc but when it comes to this stuff, I wonder if I need to look else where. Not sure, I wouldn't want to buy a bluray player and find it still doesn't function with DTS![]()
It's not, I also use a PC, Switch etcIs your PS5 the only source you use?
It was set to Auto, just changed to passthrough but no change for that particular movie.You could log a ticket to Sonos but remember there are many different audio formates. What is your TV set to under eARC settings? Is it pass through?
Hi what is the other movie encoded in? IE Dolby Digital or DTS?It was set to Auto, just changed to passthrough but no change for that particular movie.
Has to be that LG isn't accepting the signal, so it's just downgrading it to 2.0 but just weird that another movie does come through at 5.1
I'll have to check, will have a look later todayHi what is the other movie encoded in? IE Dolby Digital or DTS?
