But yeah try these changes in karhu and see if it's any betterPeak GB! there's are reason we don't touch that brand for oc'ingBut yeah try these changes in karhu and see if it's any better
I'm sure another BIOS update or two will sort that 4000 kit
So far the RAM test is still running, no errors at all. I will let it get to 6000% assuming it stays like this and after that point I can be confident in general stability and then retest Cyberpunk 2077. If that is then also free from any CTD then that's stability fully sorted in and out of high end gaming
Edit*
Should I keep running it? At present the error detection rate according to the FAQ is 92% or more, it will hit 99% when it gets to 6400% coverage but is 92%+ enough to call it stable perhaps?
Next up is Ram, currently using Corsair LPX 3600 c18, but I've little to no experience in overclocking and tuning ram, any advice would be greatly appreciated![]()
Be interested to see if you get anything out of this as sounds like we have the same memory? Mine is CMK64GX4M2D3600C18
Is Multi Core Enhancement set to Auto or Enabled in the BIOS? Enabled will max turbo the cores at all times, auto won't. This might explain the rather swift jump to 100 degrees.
