They wear masks in your area?
Didnt get chance to buy any sims on the way home but used the apps to check and see what i could get with vodafone on my phone. Sadly vodafone only has 3 aerials on my local mask and according to cell mapper none of them point directly at my village and i am between two of them.
I can see both of them on my phone and as i move around the house, my phone jumps between the both of them. only 3/4 bars on either.
Inside it fluterates between 3- and 12 Mbps. Outside in the garden though I was getting a solid 40Mbps on vodafone which gives my high hopes for something better from EE.
I had a look at the my local mast and i see that O2 has a cell covering my village on the mast and it has data that the av download speed is 126Mbps and 26Mbps upload.
So hopefully either O2 or EE should be the ones to go for
Anybody know if O2 are truely unlimited or is there a cap please?
Well that seems pretty positive re: the outside signal strength.
Even if you had to use Vodafone you could always opt for an MVNO like Voxi and to test O2 you could go with a month of GiffGaff, both options are £35 with no contract, just a months usage. That just leaves EE to test, to be honest I'd probably just use them for a whole month if you do get a good connection, and monitor what the stability is, and connection speed at the various times of the day. It'll take 3 months to do a complete test of all the networks and you'll get a much better feel for what is possible, only pain in the bum would be moving the antenna if required, but I guess you can check just how close the masts are to each other, some may/will be shared.
Luckily for me they are all on the same mast, the one I can see from my house.
So once i set up an external directional antenna I should be good to go to test between sims.
Be careful if going with a fully directional antenna as you'll need proper equipment to set it up, or spend a couple of days adjusting it by a mm or two, also your up/down angle plays a big part. Getting a good Poynting Omni directional would be much easier, and you'll end up will similar results as you aren't 20Km away just a few.
I shall bear that in mind, thanks.
This is all so new to me, having to read up and learn lots fast
Thanks for all your help.
No problem.
That's why I suggest the cheapo 4G router, to get some hands on experience with the technology, makes a lot more sense than just reading sometimes.
Did you figure out if you have a window in the right place for just getting indoor reception before you commit to an external antenna?
Got a b535 coming so will check indoors in the windows first. Certainly with vodafone, even with my mobile in the window it isnt even half as good as outside on the ground in the garden.
O2 or EE may be different.
Will get an external aerial later for stability more than speed if needed.
Higher up isn't always better, as pointed out above, the up/ down angle is very important, so being at ground level may out put you in better alignment with the cells on the mast, as they are normally angled down.
get a cat 19/20 router and external aerial if necessary.
Just be aware that a CAT19 or 20 receiver is pointless unless the manufacturer has made allowances for the number of combined 150Mbps chains. On the Mikrotik Chateau 5G for example it's a CAT20 chipset but they only fitted 4 antennae so potentially it's hobbled to CAT6 speeds on LTE. It has the spaces (holes in the back of the case and connectors on the mainboard) for another 8 antennae but they're not physically installed. To be honest, because I'm using mine in 5G mode I've not bothered trying to install the missing antennae but some users on the far east Asian Mikrotik user groups have reported massive speed increases on LTE by fitting more antennae.
I thought the b818 was 8x8 MiMo for LTE and 4x4 MiMo for the 5GHz AC WLAN? It should be quick. Certainly my LTE guy rates them very highly.
[Edit]I just re-read that statement and "my LTE guy" is our antenna installer so please don't think I'm having delusions of grandeur![/Edit]
I had one before I replaced it with the CPE Pro 5G, there are two versions, the 818-263 which is the one I had was 4x4, I am pretty sure anyhow. However yes it was a great device, but I only paid £183 brand new delivered, it also only has 2x2 MIMO external ports.
Perhaps you are right, difficult to find out exactly. But I would have assumed it had all the necessary internal aerials for its quoted speed. The issues only comes about if you want to use external as you drop half the speed unless you buy a modded one.
Oh totally forgot to say earlier, if you want to give Vodafone a go, you can sign up for the Home Broadband on a 30-day contract for 100GB (£30), and get a B818-263 for £100.
Link! - select 4G from the round buttons, and 30-days from the options, routers are fully unlocked and you can keep it even if you only pay for one lot of 30-days plus the £100.
