Thanks don't know how I missed that.
Do they ship to the UK though?
They do iircDo they ship to the UK though?
They do iirc
Or contact OCUK through the CS sub forum and ask them to get some in?
At least you cant choose UK in the list of countriesI messaged them yesterday about that and they don't unfortunately. It would be pretty strange for them to stock the UK version but have no way for them to be available in the UK. Overclockers must surely be getting them in at some point.Doesnt look like they doAt least you cant choose UK in the list of countries
Ill see if OCUK are getting them
Hey,Hey Space Monkey cracking setup, How was fitting the plate? easy enough?
I have big hands so am fine without a wrist rest at theDo you guys with Pros find you need a wrist rest? Exactly how high are the keys from the desk? My current keyboard is about 29mm high from the desk to the top of the key caps on the bottom row of keys, and I just about manage without a wrist rest, but I am not sure I would want go any higher.
Mine are liveable but not amazing. I think @Space Monkey used the Durocks but had to mod them to fit??Do the newer GMMK Pro's come with bad stabilizers? Are Durock v2's a must and if yes, besides the stabs, what else do I need to install them (lube, tools etc)?
Yeah with the Brass plate (and Alu plates as well) you need to mod them to fit but it only takes about 10 minutesI have big hands so am fine without a wrist rest at the
So with the standard plate they would fit fine?Yeah with the Brass plate (and Alu plates and well) you need to mod them to fit but it only takes about 10 minutes![]()
The standard plate is the Aluminium plate, so that'll need a bit of modding, only the plastic plates seems to work ok but that's just due to it being easy to force the stabs through it.So with the standard plate they would fit fine?
How are things with the GMMK Pro now? Any small revisions to launch hardware and what about the VIA support?
Probably some tiny bits here and there but nothing major as for via it was added to the via firmware download page 6 months ago so should work.
