The OCUK Whisky (and Whiskey) review thread
9 Nov 2009
Planet Earth
Someone in the States told me Yamazaki 12 is $200 plus over there online and that’s not including taxes or shipping. Locally in a store it can be as much as $300!
I will also pick up Nikka 12 before April too, for comparison to the Yamazaki.
Wow,UK pricing doesn't seem as bad! Nikka 12 is around £125,so probably another whisky I am more liable to try via a sample.
Nikka From The Barrel is surprisingly gentle/subtle for over 50% ABV - found the Coffey Malt and Hibiki 12 to be somewhat fuller.
Caporegime
20 Oct 2002
Wish i was in a Ramen Shop Counter
Hibiki 12 cost too much these days, that’s discontinued. I heard good things about the Coffee Malt, that’s on the list and not too expensive.
9 Nov 2009
Planet Earth
I managed to get the Nikka for £30ish for 50cl on Amazon - I did prefer the Coffey Malt but only had a small tipple from it,but it is slowly growing on me. Like the Coffey Malt its blended with some whisky from the Ben Nevis distillery so isn't technically 100% Japanese whisky - the Coffey Grain is 100% Japanese sourced but reviews worse!
BTW,WRT to Hibiki this video about it is fantastic:
https://www.youtube.com/watch?v=YGRoj0SXftU
That guy is a Brit living in Japan,and its a really great place to keep up with some of the releases over there.
28 Aug 2006
Hexham
It's time for a little 'recommend me something different please?'
I'm normally a sherry cask finish man, Bunnahabhain 12 being my current favourite, along with Redbreast, but I feel like experimenting.
I'm thinking maybe an Ardbeg, Caol Ola, Laphroaig, etc, any others please, up to around £40?
25 Jul 2010
Worcestershire
Of the Islays you've mentioned, the standards (i.e. worth the money and always available, and worth trying before anything more expensive or experimental) of those to try are the Ardbeg 10, Caol Ila 12 and Laphroaig 10. None objectively better than the others (Caol Ila generally less 'heralded'), just pick the one you fancy.
Away from Islay for non-sherried whiskies, try Kilkerran 12 or Springbank 10 if you can find them for 40 quid, sometimes you can if you're lucky. Otherwise Ledaig 10 is also very good and easy to find in stock.
25 Nov 2020
Laphroaig Quarter Cask is very nice. In my opinion it's better than the 10. Have you tried smoky or peaty whisky before or would this be your first experience?
28 Aug 2006
Hexham
Thank you, I'll have a look at the ones you've suggested too.
The only one I can really remember was Laphroaig (probably the 10) about 25 years ago and I hated it, probably about time to try again.
9 Nov 2009
Planet Earth
Laphroaig 16 is on offer at Waitrose:
https://www.waitrose.com/ecom/produ...-single-malt-scotch-whisky/053792-26970-26971
Apparently it might be closer to £100 near the end of the year due to potential price increases.
Also shame you didn't ask a few months ago,as Bunnahabhain Moine was a relatively heavy peated Bunnahabhain. Bunnahabhain Toiteach a Dhà apparently does have a degree of peat in it,but also uses Sherry casks and AFAIK is less peated than Bunnahabhain Moine so could be a compromise:
https://www.amazon.co.uk/Bunnahabhain-Toiteach-Single-Scotch-Whisky/dp/B07BXM2CSW
You can also get smaller 20cl sampler bottles of it to try:
https://www.amazon.co.uk/Bunnahabhain-Toiteach-Dha-200ml-Bottle/dp/B095KN2N8R/
There is also this independent bottling of another peated Bunnahabhain :
https://skenewhisky.com/product/bunnahabhain-peated/
22 Jan 2014
I really recommend a really recommend an Islay tasting set before getting a full bottle. Peat varies so much between distilleries that a taste of e.g. Bowmore 12 may make you queasy, whilst Laphroaig 10 might leave you going back for a lot more (both true for me). Lots of different sets available usually for £25 or under.
20 Oct 2002
London
I wouldn't really describe Bunnnah as a typical sherry finish, it's quite unique (and wonderfully so). Along those lines I would try as mentioned above.. Kilkerran, Ledaig and definitely Springbank will give you similar flavours but also unique in their own way. Shout out for Glenfarclas too as a more straight-up sherry finish.
If you've not gone all in for peat yet, tread carefully. Laphroaig Quarter Cask is fantastic and won't break the bank if you find you're not so keen. You could also check out Longrow which is Springbank's (mildly) peated release which would be a fantastic step towards Islay whiskies. If you can find it.
28 Aug 2006
Hexham
Cheers, I've looked at the quarter cask a few times, think I've probably narrowed it down to that or the Caol Ila this time around, I'll see what comes up on offer.
25 Nov 2020
Either of those are a solid choice. If you hated the Laphroaig 10 back then I'd advise against it being your first choice to jump back in with.
Staying on Islay but moving from smoky is the Bunnahabhain 18. A real beauty, albeit in the next price bracket up.
9 Nov 2009
Planet Earth
Bunnahabhain makes peated expression as I mentioned before,so if you like the Bunnahabhain profile but want more peat,then its worth trying one of those IMHO. Bunnahabhain Toiteach a Dhà is peated but uses sherry casks too - both Bunnahabhain 12 and Redbreast 12 use sherry casks.So you will get the sherry "sweetness" but also peat at the same time.
12 Jun 2016
North West
Tried the Haig tonight for the first time, was an Xmas gift. Wouldn't choose to buy again tbh tastes like a more vanilla version of jack. Tried over ice first and wasn't a fan so then moved to mix with coke.
28 Aug 2006
Hexham
Thank you, I've narrowed it down to 3 then, lol!
I'll do some more research today and get a bottle ordered, thank you all again.
9 Nov 2009
Planet Earth
I'm an all or nothing kind of guy, lol, go big or go home! :cry:
:D
There is also this independent bottling of another peated Bunnahabhain from an independent bottler:
Distilled in 2013 and bottled in 2020,so about 7 years old. But its "small batch" and comes from only two casks. Gets decent reviews:
https://topwhiskies.com/blogs/whisky-reviews/a-review-of-skene-scotch-whiskys-bunnahabhain-peated
https://whiskyreviews.net/2021/01/2...hiskies-blair-athol-tomatin-and-bunnahabhain/
28 Aug 2006
Hexham
:D
I've bookmarked that one for a later date, sounds lovely, I've got a £20 Amazon gift card burning a hole in my pocket, so that's where this bottle will be coming from.
