Hi All, I've just installed my AC6Lt and Aquaero software, and in the process of getting my head round it all !
So sorry for the raft of incoming newb questions
First one ... how can i manually control my fans so that I can find their maximum RPM ? >> This is purely so that i can set the range correctly in the gauges and charts for displaying on my second monitor.
In the xmal coding, it uses colour brush numbers i.e. Color15Brush >> is there a reference somewhere that describes the colour ranges ? all I can find online are Hex and RGB codes.
Unfortunately markup language is a mystery to me, i'm dyslexic and it's basically unreadable to me !
Last for now ... If i want to attempt to use ambient temp delta, where exactly do you put the sensor ? does it need to be outside of the case ? or if you put it on the inside does it need to be away from air being blown by the intake fans ?
Many thanks
Damian
Many thanks
Damian
So you may find it's easier to use a visual reference. You can pick the exact colour you like off a chart then just copy the values.
.. but that sounds like all sorts of fun
