That recipe should give you 6 balls at 250g. If you want to freeze then you will be fine. If you use cling film or something similar, advise once you take out of the freezer put in a container. When defrosting it can make it a bit messyThanks for this, I have one question once I make the dough, say I make enough for 4 pizzas, can I freeze 3 dough balls straight away after making.
I might try the ooni recipe next, I have been using bread flour, seems like 00 grade flour is good to use as well.
I was just a little unsure about storing the dough for a later date.
nice selection -A few from this weekend
nice selection -
Divisive question then - are you regularly using a(which) stand mixer given your high production volume (I'm lazy and am typically using the Pan bread machine, which is probably inferior to a stand)
Do you put them in the oven back to back or allow some recovery, too ?
the efficacy+asthetic of the spiral is hard to repress -but, for dough, anything less than a spiral hook in in a KA600 looks meh
Yeah just blobs, or stir some into some base sauce.Short of ingredients for toppings and have a base in fridge that needs to be used any ideas for toppings, I have some grated mozzarella and some Nduja, would that work?
Actually how do you top your pizza with nduja, I normally just put small blobs of it on, is it better to spread it.
Or no base and just nduja topped with cheese.
Toppings ideas though, IMO try anything and everything screw sticking to traditional.
Did you just blend them up. I've done it with some Costco vine tomatoes that were past there best. I roasted them first, then just mashed them. I read somewhere you should never blend tomatoes as the seeds once broken apart don't have a pleasant taste.made up a tomato base from fresh (supposedly vine aldi) tomatoes - about the same weight as a can - an underwhelming experience I won't repeat
taste(and colour) was not there compared to Cirio;
maybe it's true the weight of fresh tomatoes going into a can is much greater than DIY weight equivalent.
I have a kmix but I find that using it to make dough from scratch is a faff because it takes forever to add tiny spoonfulls of flour near the end of the mix, and can actually be quite messy.yes - I will have to try the stand mixer , although after looking into dough hooks design , on Rays ka thread
Spiral Dough Hook for KitchenAid Artisan?
(& could be why the uk bake-off show , KA kitted contestants currently manually kneeding dough.)
Aromatic crispy duck is one of my favorite pizzas. Ive never had a white pizza before but yours look and sound delicious. Ill have to experiment...A few from this weekend
62% Hydration / 72 Hour Proof with Poolish Starter
Prob my least favourite way to prep dough but I go back to it time to time and try to tweek and improve.
Pizza Bianca
- Base of Ricotta and Cream gives it much more subtle flavours.
- Thinly sliced Garlic and olive oil
- Topped with Smoked Mozzarella (Scamorza), Parmesan and Rosemary
Mushroom and Italian Sausage
- Chestnut, Oyster and Foristiere Mushrooms, cooked in Garlic Oil and Oregano then blitzed into base sauce
- Fior Di Latte Mozzarella
- Tuscan Sausage Meat with Fennel and Garlic
- Finished with fresh Parmesan
Peking Pizza
- Tomato sauce base infused with home made Szechuan Chili Oil
- Slow roasted duck with Hoisin and Plum sauce
- Fior Di Latte
- Finished with Springs onions, Black Sesame Seeds, Sprinkle of sesame oil
Really nice blend of heat and sweet.
Christened my first ever pizza oven, an Ooni Koda 16, at the weekend.
Much to learn, but delicious and great fun.
.Awesome, I'm thinking about getting one this year, how did you find it.
I currently use a gas oven which is fine, but doing it outside and in a proper pizza oven must be really enjoyable. If I get one it will be the gas one, have a few of them garden patio gas bottles as well for our gas bbq, so makes sense to go gas.
I will get the 12" ooni, its hard enough making a pizza base for that size.
