- 14 Jan 2013
- Horsham
There's more than one version of PS4S though, the BMW OE * marked version is a very different tyre to the generic aftermarket PS4S.
Lol
Mic dropWhats funny? The oe and none oe tyres are massively different. Different enough that the OE ought to have been called a different name
https://www.carthrottle.com/post/oe-tyres-vs-off-the-shelf-heres-how-different-the-same-tyre-can-be/
Has it![]()
Thanks I was trying to work out what the packs were on the 2018 model so that helps, though it was mentioned above too to be fair. I will have a drive in a bit in the dark but I do miss the lights from my old 5 series which were superb. E220's were dire, I mean really really bad and the GTR's though much better are still not a patch on the former 5 series I had. Roundy corner lights me like.Yes, I think they make or break the front end aesthetic, the standard lights, while functionally fine, look a bit cheap.
Almost nobody specs the BMW Icon Adaptive lights, I'm sure they are very good at night too, the beam will adjust as you drive along automatically to keep more of the road illuminated - usually works well.
Collected the 530D today, so far so good.
that's very nice, done 6k miles in mine (Touring) from new in past 16 months, would have normally covered, oh, 25k miles. Like you say, prefer it to F11 I had before, although 535D engine was a bit stronger with a better growl. I would 100% have gone for a 340hp 540D which they sell on continent only I think?
There's the BMW ConnectedDrive app, it might take a few days before you can register the car though.So are there any Apps I need to download/subscribe to for this car?
Yea downloaded a couple will give them a nose.There's the BMW ConnectedDrive app, it might take a few days before you can register the car though.
I don't think the BMW one can do that. I find it quite poor to be honest, I only use it to see how much fuel it doesn't have.I have a couple for my Merc and they work well, really like the ability to zone the car so if it starts or moves etc I get a message.
Wait, I thought that was for Pies?I'm not sure that parking sensor button is large enough!
It's an executive saloon, execs ain't got time for finding no button!I'm not sure that parking sensor button is large enough!
B'stard salesman, he said
