- 20 Aug 2019
Thank you. Corsair CX750M, Needs to be upgraded really.Nice.
What psu did you reuse ?
Corsair rm 750w is £75 850w is £85 ,which seems good value for a a fully modular, gold rated with 10 year warranty.Thank you. Corsair CX750M, Needs to be upgraded really.
The white version comes with white cables but a bit more expensive.
Kids showing his skills.Can’t see the PSU only the cables. So a black one is okay. Defo needs to upgrade it. Will depend on what his new card will be as well.
My sons done a quick video on TikTok https://vm.tiktok.com/ZMLRqHDnP/
I think he’s working on the video of the build as we speak but you know kids.
If you go to corsair website for corsair rm white and flick thick the images you will see white cables.
850w covers all bases if you get one before new gpu.
Yes.He didn’t do a bad job.
Umm that’s handy. So this is the right one? https://www.overclockers.co.uk/cors...w-noise-atx-power-supply-white-ca-26j-cs.html
Yes.
I just checked corsair website and the cables are definately white , check it yourself to concur.
yup, looks like max temp 81degrees, 46 at time you took captureWe ow you a beer or two for all your help thank you. So I ran R23 and here are the results. The only changes we have made was as advised to go into bios, go to AI Tweaker, then enable D.O.C.P. This has set the ram to 3600mhz. Everything else is stock.
So would I be right in saying this hit 81.1c at the max on the core?
the rm850 to RM850X...difference is capacitors in the 'X' are japanese as opposed to chinese in the non'x', with japanese being better. both come with a 10yrs waranty though. Also Corsair have released new 2021 versions...these come with a more square exhaust design made of small triangle..in theRMX series some of the parts have been upgraded and the fan was changed to magnetic levitation fan..under load it gets loader than previously(haven't heard it on mine yet, and fan doesn't spin until you hit a certain power draw) but it's far more durable so should last longer..not much said about the new RM series, but guessing they've changed the fans there too...example below shows the rm1000x(as old and new were same colour, not as these are the ones you should get), with circular design for exhaust and new square design below for new model(left old, right new)...same design goes through whole range of rm and rmx series..so you know if you getting old design or new(plus new matches design language of the 4000/5000/7000 series case)I was confused with the X option at the end. Nope that’s perfect. I will put it across the the lad
Top look...nice & clean...do like corsairs design atm
My basket at Overclockers UK:
So is that good or bad?
Just watched and gave a thumbs upMy sons just finished the video and uploaded it.
Look forward to an updated pick with those white cables.
