I must be odd, i DE shave or electric shave depending how bothered i can be.
I used to buy polsilver iridiums and iridium supers by the thousand and found them the best blades but they stopped making them now.
Still have a lifetime supply left i expect. They are not sharper or longer lasting than other blades but i seem to get less nicks with them and never had a real cut using them.
Use multiple soaps and some creams, honestly i can use cheap or expensive ones and just pick whatever.
The brush is edwin jagger best badger but i also have a Simpson chubby 2 in best badger that i never use even though it is far higher quality than the edwin one.
The smaller size of the edwin is better for me.
Also have two adjustable Murker razors, a progress and futur. Mostly use them on setting 3.5 or near there.
Used to use gillette multiblade razors as a teen and early 20`s and have nothing against them.
I just find them expensive mostly
I have no idea who would continue to use that crap, although the non-razor products are great.
