Check your motherboard QVL list would be my recommendation for compatible memory configurations, as well as gathering feedback from users here.
Go here, select your CPU and then you can filter various validated memory configurations by the motherboard manufacturer.Oh yes sorry motherboard is msi Mag tomahawk z490
ThanksI use HWInfo with OSD via Rivatuner
@Duckwave sorry for late reply hopped on WZ and dropped textures down to low and game runs butter smooth as you said, 0 micro stutter ... though the ground and other textures look awful
Will try on normal next
I'm glad it worked for you pal. Hopefully we can figure out how to run normal.
Are you on 16 or 32gb RAM?
Normal textures is virtually stutter free other than at start at peak... I will change nothing untill I get the ram tomorrow and re test and see
Downloading Warzone again overnight, gonna have another quick play to remind myself why I don't like it.![]()
Sorry, at the start of a game at peak when it's very busy on br quads peak is the location in the middle of the mapWhat is At start at peak exactly?
I just played 3 games of Plunder stutter free with Normal. It stuttered for the first 10 minutes and I kept tweaking settings. Then it just stopped stuttering. I'll go on again in 30 minutes and see if it starts to stutter again.
Do you have texture streaming on?
I love Vanguard. No messing around, no camping just go round the corner shoot enemy, move on to next corner, shoot enemy etc. Never a long period between the next encounter.Each to his own mate, but how you can prefer Vanguard is beyond melol
Still not sure what you mean never mind.Sorry, at the start of a game at peak when it's very busy on br quads peak is the location in the middle of the map
Still not sure what you mean never mind.![]()
I am at work this morning and have a 32gb cl14 ram kit coming this morning also to replace my old 16gb
