Amazing, running very low on the textures has worked, completely stutter/hitch free 220 lows 330 highs, average of 260 over 30+mins play time, the 6900xt is unbeatable on warzone.
Footage please gentlemen.Yup. I discovered this fix a couple of days ago. It appears to be VRam related. The higher the settings you use, the more VRAM required. You could probably run normal if you disabled caching and changed map resolution to low.
But very low never fails. And this game at 200fps + on a 240hz monitor is amazing.
