Caporegime
- 9 Nov 2009
- Planet Earth
The trouble is that price performance in the GPU market has been stagnating for the last 5 years or so especially at the lower end where the same money tends to get you a lower tier down every generation which isn't much faster than the tier up from the previous gen while at the higher end prices keep ballooning and dragging everything else up so really you're forced to spend more else you don't even end up getting much better than you had before.
The issue is not only the top going up,it's also the class of dGPU you are getting as you go down the range. But its really weird that things such as cars can have luxury models,but these don't affect mainstream ones,but with electronics this game gets played. But it's also the reason why consoles are even more relevant than they should be. The average PC gamer doesn't have the GPU and CPU hardware many have on tech forums,ie,a GTX1060 and GTX1050TI are still common dGPUs even now. What this means,unlike the era of Crysis,entry level and mainstream gaming systems are increasingly starting to not have enough processing power to enable big jumps. Instead more focus has gone onto consoles now. Both Nvidia and AMD have to be blaimed for this,as they have no real want to compete too hard as it's easier just to mildly poke each other. It was like the smartphone market a while back when Apple and Samsung just did the same,but Chinese OEMs came along and gave them competition(especially in the mainstream pricing tiers),forcing them to awake from their slumber.
