I've been running 5.1/4.0 @ 1.22V on a 12700K for a few weeks now, rock solid.
Fixed voltage or have you got offset or adaptive doing its thing?
Adaptive is the way to use these CPUs with TVB and V/F curve points set correctly.
Is there a guide for this?
Ah, it’s only possible on ASUS boards? Think I’ll stick with fixed voltage unless it leads to accelerated degradation.
No all boards have that feature set, as its been that way since Comet Lake, Alderlake just builds upon that.
Do you have any proof "fixed voltage unless it leads to accelerated degradation" on these CPU's?
No option to adjust the TVB points on my MSI board.
I wasn't saying it did lead to degredation, it was more a question of whether it will. If not, I'd rather just use a fixed voltage instead of faffing about as the power usage at idle is barely any different.
Recently noticed by temps when idle or normaly using the PC are lower than when I first built the system, rather impressed. I guess its a mix of the paste settling in fully now, and a couple of rpm tweaks I did in the BIOS for the fan curves. You can see the rpms in the screen below. I'm basically at room temp now with an ultra quiet system
