** KOLINK CITADEL MESH + MESH RGB M-ATX CASES - OUTSTANDING VALUE **
Don
19 May 2012
Spalding, Lincolnshire
Got one of the ARGB Citadel Mesh cases for one of my Kids for Christmas, and have to say very impressed for the money.
@ChugNorris - Don't suppose Kolink offer any adapter cables to convert between the ARGB mini connectors on their controller and normal 3 pin ARGB cables?
If not, I don't suppose anyone knows what the connectors are called:
White connectors in this picture: https://img.overclockers.co.uk/media/image/thumbnail/CA052KK_251809_750x750.jpg
OcUK Staff
OP
26 Nov 2014
Stoke
Not sure but that's something I will look into.
Don
19 May 2012
@ChugNorris
In case anyone else stumbles across this - the connectors are JST-PH 3 pin connectors.
I used a ready crimped assembly from here:
https://thepihut.com/products/jst-ph-jumper-assembly-3-wire
Cut the end of an ARGB extension lead, and then solder the corrected wires together and then heat shrinked.
End result, a standard ARGB header that you can then daisy chain normal devices off (I tested with a Kolink ARGB strip and a Rajintek 92mm ARGB fan)
13 Mar 2004
Norfolk
Can anyone help me with something please?
I've just ordered this case along with a new system. Im planning on cooling the CPU with a 240mm AIO but its just dawned on me the roof looks a little tight for space. I can always just use the front of the case if push comes to shove.
Anyone got any experience with top mounting a 240mm AIO in these cases?
Much appreciated.
10 Dec 2004
Oxfordshire
Much appreciated.
Hey
You will be fine, I have been using a 240mm Coolermaster in the roof of mine for the last year or 2. its much wider than it looks and there was plenty of space length and width wise for the cooler with 2x full height 120mm fans on it.
If you want any photos of my setup for a bit more clarity, just shout :)
