If we're talking about direct replacement then If you don't do data-intensive work, there won't be much benefit, though down the road there may be some with direct storage.
If you need the storage then yes but just for the sake of it , no.I use my PC mainly for gaming, the extra storage would be nice (I could put my current NVME in a caddy) but not sure if it's worth upgrading
If that's your main drive, changing from crappy QLC to TLC sure wouldn't be bad thing.
Having done similar, I saw no noticeable improvements outside of benchmarks.
Hmm, not worth the upgrade then from what I'm hearing
Probably not unless you need the extra space and are upgrading for that.
Be careful of the big drop off in QLC performance when they're getting near full, the cache space drops off fast and they're really slow to write to when the cache is exhausted.
The extra space could always be nice though, I'd like to be able to keep more games installed at one time
Is the SN850 the one to go for if I did want more storage or should I look at something else
SN850 is a top tier drive and there's been some good deals this week.
The issue is, I'm using a B450 Tomahawk max which I believe is Gen3, the SN850 is Gen4, will that cause any issues
No issues but you may as well save some cash and get a Gen 3 drive for half the price.
Should have mentioned that your board was only Gen 3The issue is, I'm using a B450 Tomahawk max which I believe is Gen3, the SN850 is Gen4, will that cause any issues
.Should have mentioned that your board was only Gen 3.
Definately not worth it.I forgot to mention it
I was considering upgrading to B550 but again I'm just not sure if it's worth it. Seems to be only a slight sidegrade
