Dying Light 2 PC Tech Review
Don't think Deathloop had reduced preset options for dlss???
However, being the self entitled Nv user that I am, by not adding UQ FSR...
For dying light 2 it's a weird setting in the config that blocks FSR ultra quality and dlss ultra quality from being selectable
The config file dictates that only three upscale configs for dlss or FSR can display at the same time on the drop down menu, if you change the config then more options appear
So janky
Would anybody know why I don't see any RT options in the game since upgrading to a 3080 from a 980ti?
I have upgraded the drivers, and I do see the options for DLSS now, but RT options are none existent :(
https://i.~ibb.co~/PjSc5p5/Dying-Light-2-Stay-Human-Screenshot-2022-02-12-10-18-43-22.png
Do you need to select DX12 from DX11, not got the game but this happens in other titles for the RT options.
Sorry wrong screenshot before, it is in DX12, but still no RT options in advanced settings.
https://i.~ibb.co~/Qdtmbyy/Dying-Light-2-Stay-Human-Screenshot-2022-02-12-10-46-52-89.png
I have tested Control (the game...) and RT options work fine there.
Nice mod - https://steamcommunity.com/sharedfiles/filedetails/?id=2752042406
Dying Light 2 Enhanced Mod
Below you can find a list of some features.
• Adds more shadows casted by lights
• Adds more distant fog to Clear and Cloudy weathers along with other weather tweaks
• Adjusts the weather cycle so it rains more often at night time. Additionally the foggy, overcast and storm weathers will have a higher chance of occurring (Will unlock once you get to the second map)
• Increases level of detail / draw distance for trees, shadows and other objects
• Increases zombie / AI density around the map
• Removes or reduces various post-processing filters such as lens flare, sky bloom, glows, streaks etc.
• Slightly adjusts min. and max exposure values
• Slightly adjusts contrast and saturation (No need for ReShade or NVIDIA Filters)
• Removes excessive air particles such as falling leaves, newspapers, glowing fireflies etc. but keeps some effects as well
• Attempts to unlock and use various graphical settings which may or may not work
• Various miscellaneous tweaks
