Nice one.Just uploading a 5 minute recording of Rebirth Island @LtMatt
Everything on High at 1080p. Consistently 200+ fps.
6900xt is a beast!
6900xt is a beast!
Looks like great performance there in Rebirth.
Got a 3090 FE to play with, so will try and put up some Warzone videos using that soon.
It is a long way behind my 6900 Toxic Extreme in Vanguard.
Yeah, that's with my frames capped to 237 too. That's why it never exceeds that. I have a 240hz monitor, so I don't need anymore.
It's ridiculously smooth. You might like Rebirth a lot more than BR by the way. Much smaller map, much more action orientated and fast paced. I love it.
I'm done with Caldera. It's just a mess of a map and I'll play Rebirth until they either re-release Verdansk or another map.
3090? Nice. I don't think 6900xt can be beaten on WZ from what I've seen. Most cards struggle to get a consistent 200fps even at 1080p.
Yes it looked very fluid.
I think you might be right. Were you playing quads?
I'll put up some rebirth videos soon, don't expect much from me though never do very well in Warzone. Do I need to select anything specific from the main menu?
Crank it up to high and let's see how your 3090 does.Everything on High at 1080p. Consistently 200+ fps.
6900xt is a beast!
Because Warzone benefits from higher FPS which in turns gives you lower latency, which can give you a competitive edge in this game. 6900 XT is very fast in Warzone, so if this is your main game it would make sense to use one, budget permitting.Why on earth are you using a 6900xt for 1080p?
@RSR gets a nice consistent 200fps+ in 2042 too iirc in 1440p with his 6900XT OCF nicely clocked up
They are beastly indeed at the lower resolutions!
It runs well, but FPS are much lower. Copied your settings.
If I use lowest settings, it gets closer in performance to the 6900 XT at lowest settings. As soon as you crank up the image quality settings, it falls further behind though.
Ah, I thought you were running at 1440P, I would have run 1080P if I'd realised.You are playing at 1440p to be fair though mate.
The 3090 is quicker than the 6900XT Warzone from my testing, which is at 1440P. My 3090 is consistantly over 200 fps WZ, more so in rebirth as its a smaller map.
You can again a lot of performance in WZ fast RAM and Intel platform as a base.
