Lovely hubs, you can actually just pull the freehub off with the cassette in place if you wanted to save a step.
I didn't think of that - still, I took the chance to give the cassette a good scrub so that's all shiny again.
I also finally changed the front tyre. I think I posted an image before about how I was getting strange "growths" on the tyre after plugging a puncture which the sealant couldn't quite seal properly (it never went totally flat on the road, so never stranded me). The tyre had done just under 4000km.
The blue circle is where I stuck the Dynaracer plugs in - the red is a bit of the weird rubber growth that would build-up and then fall off whilst riding.
This is inside the tyre with the tips of the two plugs still there:
